osmonxp Posted August 18, 2017 Share Posted August 18, 2017 Hello, Would you happen to know where I can find the right crush washer for the CVT drain and filer plugs? I recently replaced the CVT fluid on my 2012 Subaru Legacy 2.5i and was forced to use the same washer because I wasn't able to find it, even the Subaru dealer was unable to help me since they claim that fluid is not supposed to be changed. Thank you. Link to comment Share on other sites More sharing options...
bigboy292000 Posted August 19, 2017 Share Posted August 19, 2017 Look under the car. Does it leak CVT fluid? No? You are good, the crush washer is doing it's job. Generally speaking, you can reuse crush washer several times. Unless you are over tightening or something. Link to comment Share on other sites More sharing options...
FLlegacy Posted August 19, 2017 Share Posted August 19, 2017 I wouldn't worry about it until you need to service it again. I have reused crush washers a few times without leaks. Link to comment Share on other sites More sharing options...
