Crotchasaurus Posted August 18, 2017 Share Posted August 18, 2017 Goes under the gear selector stick Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
xrayspecs Posted August 18, 2017 Share Posted August 18, 2017 The shifter ball socket, should have two orings on it to hold the bushing in place. Link to comment Share on other sites More sharing options...
Crotchasaurus Posted August 18, 2017 Author Share Posted August 18, 2017 The shifter ball socket, should have two orings on it to hold the bushing in place. Sent from my iPhone using Tapatalk where could I find one? Link to comment Share on other sites More sharing options...
xrayspecs Posted August 21, 2017 Share Posted August 21, 2017 all the ones ive seen are OEM i dont believe anyone makes that particular piece aftermarket as its hard plastic already. Link to comment Share on other sites More sharing options...
rougeben83 Posted August 24, 2017 Share Posted August 24, 2017 you'll need to get a used shifter assembly with one already on it (usually $50 or less) - those usually aren't sold separately. Link to comment Share on other sites More sharing options...
MilesA Posted August 24, 2017 Share Posted August 24, 2017 There should be a circlip at the top of that plastic socket piece to hold it onto the end of the shift lever. It's probably around somewhere, might have gone flying off into a dark corner. Link to comment Share on other sites More sharing options...
