nsr Posted August 22, 2017 Share Posted August 22, 2017 Thanks! Didnt realize it's in series. I'll check out the hammer down. Well, I believe the system is somewhat in 'series'. So if one side still has a filter and is a bit clogged, it will influence the rest of the oiling system. And yes, there is a way to take it out without pulling the intake cam sprocket on the driver side. I'll search for the post from hammerhead... It is 'hammer down', not hammerhead here you go: http://legacygt.com/forums/showpost.php?p=5355816&postcount=1097 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 22, 2017 Share Posted August 22, 2017 Well you know what, after careful rechecking of how these OCVs work, they are not really in series as I previously mentioned; at least not directly at all. From what I can tell, the OCV on the driver side gets 'fresh oil' from the head through the banjo bolt filter, and then oil goes from the OCV to the intake cam gear. On the passenger side, oil comes from the banjo bolt placed on the passenger side head, and oil goes to the turbo and avcs cam gear. So yeah, if the banjo bolt filter on the driver side was clogged, it would definitively impact the car performance but I don't think it would kill the turbo. However, P0011 definitely would since it could starve the turbo from oil. So, I can't remember if you've already done this, but do swap OCVs and see how the car performs. Finally, if you have some way to log ECU parameters (e.g. btssm), do log VVT angles Left and Right. They must be in sync at all times. I personally view these two parameters on my car at all times. It gives me peace of mind knowing that the ocvs are working as they should, and the turbo is getting proper lubrication. Link to comment Share on other sites More sharing options...
subie-roo Posted August 22, 2017 Share Posted August 22, 2017 I recently fought this same battle with my 05 LGT. P0011 and P0021. Tried everything recommended including new OCVs and camshaft position sensor. By the time we removed the drivers side banjo bolt (which was completely clogged) it was too late and the engine developed a knock. Spun a rod bearing and ended up rebuilding the engine. It might be a pain in the a*# but a clogged drivers side banjo can be just as catastrophic as the passenger side. Link to comment Share on other sites More sharing options...
nsr Posted August 22, 2017 Share Posted August 22, 2017 I'll throw the AP back on it and see what i can log with it. Link to comment Share on other sites More sharing options...
ShowMeUrOsFace Posted August 22, 2017 Share Posted August 22, 2017 I got the same, pulled the downpipe and the turbo is fine, no shaft play whatsoever. Took out the banjo bolt on the passenger side and the filter looked pretty gunked up. Followed up with an oil change and sent a sample into black stone labs but havnt heard back yet. I've driven her on a few small trips, feels fine sounds fine, the engine did start smoking but I believe that's just the mass amount of pb blaster I used on the heat shield burning off as the amount of smoke has reduced each time. Still driving quite conservatively as I'm nervous that the code will come back (I had disconnected the battery while I was replacing a wheel bearing, totally seperate but needed to be done). Also changed the VVT when I first got the code but it came back again pretty shortly after that swap so I'm pretty sure that wasn't the culprit. Good luck to you and wish me luck, I'm just gonna use it sparingly and check the oil before and after each trip for a few weeks then I can hopefully drive without paranoia Link to comment Share on other sites More sharing options...
Cfinn Posted August 22, 2017 Author Share Posted August 22, 2017 Well codes popped up again. Car sputtered a bit and I took it to an autoparts store to run the codes. It's now p0021, which I expected since we swapped OCV's sides. Looks like $122 to buy and then labor to install. Might get my mechanic to just do it for free but who knows. How hard is it to pull and replace the driver side OCV? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 22, 2017 Share Posted August 22, 2017 super easy! At least on the driver side. The passenger side may be slightly more annoying, but really it is not that bad at all. Link to comment Share on other sites More sharing options...
Cfinn Posted August 22, 2017 Author Share Posted August 22, 2017 What tools would I need? Could a layman do it? I'm mechanically inclined just don't really do car repairs. Link to comment Share on other sites More sharing options...
MilesA Posted August 22, 2017 Share Posted August 22, 2017 What tools would I need? Could a layman do it? I'm mechanically inclined just don't really do car repairs. You can check this walkthrough: http://legacygt.com/forums/showthread.php/replace-avcs-oil-control-valves-ocvs-262119.html?p=5629339 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 22, 2017 Share Posted August 22, 2017 Nothing fancy. A good set of metric sockets, some short extensions, adapters and stuff. There must be a video or how to on the site. This has been discussed many times. Link to comment Share on other sites More sharing options...
Cfinn Posted August 22, 2017 Author Share Posted August 22, 2017 The walkthrough posted is helpful, video would be great since I am not super knowledgeable Link to comment Share on other sites More sharing options...
cseagle08 Posted August 22, 2017 Share Posted August 22, 2017 On the driver's side it literally takes 5 minutes. 1 electrical connector, 1-10mm bolt (i think it's 10), then wiggle it a bit and slides right out. slide new one in - reconnect and done. It's possibly easier than changing your air filter. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 22, 2017 Share Posted August 22, 2017 +1. Have a small rag to catch the little oil that will come out. Link to comment Share on other sites More sharing options...
Cfinn Posted August 22, 2017 Author Share Posted August 22, 2017 Thanks guys, that's what I thought. Guess I'll go give it a try Link to comment Share on other sites More sharing options...
Cfinn Posted August 25, 2017 Author Share Posted August 25, 2017 Thank you to all that gave advice. After replacing the AVCS on the passenger side I swapped OCV sides and threw p0021. Replaced that OCV and it's been smooth sailing sense. Halsey Auto Parts gave me a defective OCV when I originally replaced the passenger side during my rebuild. Link to comment Share on other sites More sharing options...
FJuan Posted August 25, 2017 Share Posted August 25, 2017 Good to hear. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
