JazzAvi8r Posted August 16, 2017 Share Posted August 16, 2017 anyone know what the purpose of the manual button the side of the shift lever on my 94' legacy wagon automatic is? Link to comment Share on other sites More sharing options...
MilesA Posted August 16, 2017 Share Posted August 16, 2017 This mode is intended mostly for low-traction driving conditions. It only works in the 2 or 3 gear lever position. In position 2, the transmission will start out in 2, it will not shift up to 3. In 3, the transmission will start in 2 and shift up to 3. Link to comment Share on other sites More sharing options...
Setnev Posted August 16, 2017 Share Posted August 16, 2017 This mode is intended mostly for low-traction driving conditions. It only works in the 2 or 3 gear lever position. In position 2, the transmission will start out in 2, it will not shift up to 3. In 3, the transmission will start in 2 and shift up to 3. I always wondered this too as my SVX has the same switch. Link to comment Share on other sites More sharing options...
JazzAvi8r Posted August 17, 2017 Author Share Posted August 17, 2017 awesome thanks! Link to comment Share on other sites More sharing options...
JazzAvi8r Posted August 17, 2017 Author Share Posted August 17, 2017 just to clarify, this isn't a switch that changes it to 2WD from AWD, correct? it's merely a gearing switch for the tranny, correct? Link to comment Share on other sites More sharing options...
MilesA Posted August 17, 2017 Share Posted August 17, 2017 It just controls the shift programming, as far as I know. The idea is to give you more control when driving is slick conditions. The transmission will start off in 2nd gear, it will not drop down to 1st unless you select it. Link to comment Share on other sites More sharing options...
