FrankNature Posted August 15, 2017 Share Posted August 15, 2017 I have an 05' Outback (2.5L SOHC 5MT) and it just gave me the P0420 code: Catalyst System Below Efficiency Below Threshold Bank. So do I just go and replace both of the Cats? If I got aftermarket will a new catalytic converter improve the sound? Or should I just go with OEM? Any advice would help before I drop a $1k at autozone for both of the Cats. Sorry for sounding like a noob, and if this is the wrong place my apologies. Link to comment Share on other sites More sharing options...
MilesA Posted August 15, 2017 Share Posted August 15, 2017 P0420 can be caused by a number of different things. Just swapping parts in could be expensive and unnecessary. The best thing to do is troubleshoot the problem before you replace any parts. Either you or a competent technician needs to go through a diagnostic procedure; you can download info for your car here: http://legacygt.com/forums/showthread.php/vacation-pix-171435.html The cause could be such things as: -bad front oxygen sensor -bad rear oxygen sensor -faulty wiring -exhaust leak -bad catalytic converter If you have more questions, it might be good to post under the general forum for your car's generation. Link to comment Share on other sites More sharing options...
FrankNature Posted August 16, 2017 Author Share Posted August 16, 2017 P0420 can be caused by a number of different things. Just swapping parts in could be expensive and unnecessary. The best thing to do is troubleshoot the problem before you replace any parts. Either you or a competent technician needs to go through a diagnostic procedure; you can download info for your car here: http://legacygt.com/forums/showthread.php/vacation-pix-171435.html The cause could be such things as: -bad front oxygen sensor -bad rear oxygen sensor -faulty wiring -exhaust leak -bad catalytic converter If you have more questions, it might be good to post under the general forum for your car's generation. Thank you man I appreciate your help! Link to comment Share on other sites More sharing options...
