mikewohlwend Posted August 15, 2017 Share Posted August 15, 2017 I am looking for a install kit for a 2002 Legacy GT. The only ones I can find are not big enough to cover up removing the cd changer. Can anyone help me out finding the correct one? Link to comment Share on other sites More sharing options...
Setnev Posted August 15, 2017 Share Posted August 15, 2017 If you're installing a single DIN, you're going to need the radio pocket available from Subaru, part number: 66511FA070. Outside of that, you just reuse the stock radio brackets as Subaru did a good job on installing spec single DIN units in their cars with a full double DIN option. You'll also need metra part number 70-8901 to wire up your radio to the stock harness. Link to comment Share on other sites More sharing options...
RumbleRumble Posted August 16, 2017 Share Posted August 16, 2017 I went from oem double to aftermarket single. I already had one pocket. I went to the junkyard and got a pocket with the cover on it. Link to comment Share on other sites More sharing options...
Sara32013 Posted August 16, 2017 Share Posted August 16, 2017 I am looking for a install kit for a 2002 Legacy GT. The only ones I can find are not big enough to cover up removing the cd changer. Can anyone help me out finding the correct one? No kit really needed. If you are using a double din, all you need is the harness. They are dirt cheap on eBay. If you're going you with a single din, you'll need a pocket and the harness. I was lucky enough to find a person parting out a Forester when I did my radio. I've upgraded to a double din since then and I have an extra pocket. I would let it go pretty cheap but by the time you pay for shipping it probably wouldn't be worth it. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mikewohlwend Posted August 17, 2017 Author Share Posted August 17, 2017 If you're installing a single DIN, you're going to need the radio pocket available from Subaru, part number: 66511FA070. Outside of that, you just reuse the stock radio brackets as Subaru did a good job on installing spec single DIN units in their cars with a full double DIN option. You'll also need metra part number 70-8901 to wire up your radio to the stock harness. I went from oem double to aftermarket single. I already had one pocket. I went to the junkyard and got a pocket with the cover on it. No kit really needed. If you are using a double din, all you need is the harness. They are dirt cheap on eBay. If you're going you with a single din, you'll need a pocket and the harness. I was lucky enough to find a person parting out a Forester when I did my radio. I've upgraded to a double din since then and I have an extra pocket. I would let it go pretty cheap but by the time you pay for shipping it probably wouldn't be worth it. Sent from my iPhone using Tapatalk Thanks for the help. I already have the wiring harness, just was having trouble with the install kit part. I am going to check the local junkyard this weekend to see if they have anything. If not I will message you Sara32013 Link to comment Share on other sites More sharing options...
