keane Posted August 15, 2017 Share Posted August 15, 2017 Noticed oil all over the power steering pump today, feel like it's an oil leak.. if so, where do I start? Thanks Link to comment Share on other sites More sharing options...
apexi Posted August 16, 2017 Share Posted August 16, 2017 Looks like it might be coming from the power steering o-ring. I would have some extra ATF-HP on hand, you'll lose a little fluid if you replace the o-ring. Picture of a new o-ring http://legacygt.com/forums/showpost.php?p=5091736&postcount=115 Whole thread on the topic. http://legacygt.com/forums/showthread.php/power-steering-o-ring-fix-197481.html Link to comment Share on other sites More sharing options...
keane Posted August 16, 2017 Author Share Posted August 16, 2017 Yeah okay, I also just remembered for the past few weeks there's been a squeak when wheel is near full lock, most likely something to do with this then? Link to comment Share on other sites More sharing options...
keane Posted August 16, 2017 Author Share Posted August 16, 2017 Actually on second thought, there's some fluid on the PS belt from the leak, most likely the reason Link to comment Share on other sites More sharing options...
MilesA Posted August 16, 2017 Share Posted August 16, 2017 Yeah okay, I also just remembered for the past few weeks there's been a squeak when wheel is near full lock, most likely something to do with this then?The o-ring problem can lead to a whining noise. A squealing noise is usually due to a loose or worn-out v-belt on the power steering pump. Link to comment Share on other sites More sharing options...
