RustyRuu Posted August 11, 2017 Share Posted August 11, 2017 I guess my question is who has what, i think id rather have something with a zerk so that it is grease-able (outer rod). moog does not have that on the ones i've seen online Link to comment Share on other sites More sharing options...
SixBarJ Posted August 11, 2017 Share Posted August 11, 2017 This may not be an answer and should be considered a response. Moog makes quality products and from my experience, the boot usually loses integrity before the joint does. Most subarus are light vehicles with not a lot of clearance, I believe a zerk might be at target to get 'knocked off'. If you need to replace the same ball joint multiple times, something else is going on - mechanical or heavy driving habits (like cranking the steering wheel while the vehicle is stationary, torquing the joint). I usually buy lifetime guaranteed products and they outlast other essential, expensive parts which compromises the life of the vehicle. In summary, I don't think a zerked tie-rod or ball joint end is important for the life or safety of most subarus. My two-cents -- Ken Link to comment Share on other sites More sharing options...
