Marvick08GT Posted August 13, 2017 Author Share Posted August 13, 2017 Update : had air in cooling system... That didn't occur to me because I had a performance shop vacuum the system so this didnt happen.. 185-205 now After reading, it looks like the car is supposed to have 2 different caps. Mine has the round 1.08 on the turbo tank and radiator? Link to comment Share on other sites More sharing options...
Rhitter Posted August 13, 2017 Share Posted August 13, 2017 That's wrong. It's the eared on the turbo tank the round one on the radiator. It's really important to have the right ones on in the right places. Underdog posted a few pages back in the WDGDTY4GLGT thread with the part numbers for both caps. My OBXT build Link to comment Share on other sites More sharing options...
Marvick08GT Posted August 13, 2017 Author Share Posted August 13, 2017 That's wrong. It's the eared on the turbo tank the round one on the radiator. It's really important to have the right ones on in the right places. Underdog posted a few pages back in the WDGDTY4GLGT thread with the part numbers for both caps. Appreciate it, temps are normal now. I'll order both caps. I did some logs yesterday and today, just been busy. I'll try and get them up in the AM Link to comment Share on other sites More sharing options...
d22597 Posted August 13, 2017 Share Posted August 13, 2017 I have not used S#, only sport and i-mode Is S# any different? Depends on your tune. Some tuners set different targets/parameters for S#. My S# has a more aggressive tune and hits higher boost. Link to comment Share on other sites More sharing options...
rebourne Posted August 13, 2017 Share Posted August 13, 2017 Short update..... My 65C piece of garbage fuel pump burned out while tuning E85. The tune won't be done till Wednesday. As far as spool is concerned I have to admit I'm somewhat disappointed. Full spool at aproximatly 4300 rpm and that's on E85. I haven't driven the car yet and the tune isn't completed yet, but improvement in spool is not expected. I have yet to drive the car so perhaps my opinion will change then. On paper though it is a dud. Full boost is 23-24 psi fyi. By full spool, you mean peak boost? I'm hitting 23 psi @ 3650 on my stock VF52 logging with the AP and plotting with virtual. We couldn't finish that tune because of my clutch slipping at the torque peak. pic thread build thread Link to comment Share on other sites More sharing options...
rebourne Posted August 13, 2017 Share Posted August 13, 2017 The agreement was for me to keep my original turbo I paid for. I will speak to them and see if we can work something out. If not, I'm building a motor anyway, then I can stretch the x500+ 's legs Any update on your end? You should show them the results and ask them which one you should keep, lol. I think it's obvious but maybe they will have some insight you can share with us. pic thread build thread Link to comment Share on other sites More sharing options...
Gabo Posted August 14, 2017 Share Posted August 14, 2017 By full spool, you mean peak boost? I'm hitting 23 psi @ 3650 on my stock VF52 logging with the AP and plotting with virtual. We couldn't finish that tune because of my clutch slipping at the torque peak. Yes peak boost (24 psi), my VF52 though is heavily modified. It is a Stage 3 from SoCal Porting, ported and with upgraded wastegate. Here is the info as provided on their website. ''52.60mm Inducer, 65mm Exducer, 69.99mm Tapered Tip Stage-3 compressor wheel is the largest wheel we can shove in the stock 2.4in housing. This wheel is similar in size to a 20g and comes in a billet 7×7 blade configuration to help spool but also make great mid-range and top-end HP.'' I guess 4300 rpm with a wheel equivalent to a 20G isn't so bad. What are your numbers? I'll find out Wednesday what I made on 91 oct. and how much on E85. Link to comment Share on other sites More sharing options...
Marvick08GT Posted August 14, 2017 Author Share Posted August 14, 2017 Sorry about the logs, got thrown off a supercharged jetski at 75mph... I'll try and get the logs up soon. Link to comment Share on other sites More sharing options...
rebourne Posted August 15, 2017 Share Posted August 15, 2017 Yes peak boost (24 psi), my VF52 though is heavily modified. It is a Stage 3 from SoCal Porting, ported and with upgraded wastegate. Here is the info as provided on their website. ''52.60mm Inducer, 65mm Exducer, 69.99mm Tapered Tip Stage-3 compressor wheel is the largest wheel we can shove in the stock 2.4in housing. This wheel is similar in size to a 20g and comes in a billet 7×7 blade configuration to help spool but also make great mid-range and top-end HP.'' I guess 4300 rpm with a wheel equivalent to a 20G isn't so bad. What are your numbers? I'll find out Wednesday what I made on 91 oct. and how much on E85. I don't have real numbers, just Virtual Dyno, because etune. Something like 322hp? Seems low, but like I said, we only had 3 revisions before clutch slip made it impossible to collect logs. I don't have a torque number because clutch slip causes VD to inflate the number to something ridiculous like 460 ft-lbs at 3600 rpm . I dropped back down to 91 and now I don't slip, (well, when hot I can get it to slip if i beat on it just right). Edit: forgot that I posted the VD in my build thread: http://legacygt.com/forums/showpost.php?p=5602888&postcount=190 pic thread build thread Link to comment Share on other sites More sharing options...
Gabo Posted August 15, 2017 Share Posted August 15, 2017 I don't have real numbers, just Virtual Dyno, because etune. Something like 322hp? Seems low, but like I said, we only had 3 revisions before clutch slip made it impossible to collect logs. I don't have a torque number because clutch slip causes VD to inflate the number to something ridiculous like 460 ft-lbs at 3600 rpm . I dropped back down to 91 and now I don't slip, (well, when hot I can get it to slip if i beat on it just right). Edit: forgot that I posted the VD in my build thread: http://legacygt.com/forums/showpost.php?p=5602888&postcount=190 To be honest is not power figures I'm really concerned with, but mostly the "personality" of the car. To have a somewhat fair comparison I would have to log and use vd like you. Then again the gear ratios in our cars are different. Can't wait for Wednesday to come around, I haven't gotten to truly enjoy the car in almost two years. Link to comment Share on other sites More sharing options...
rebourne Posted August 15, 2017 Share Posted August 15, 2017 On E85 and my half way in between OB and LGT tire size, with OB final drive, it got up on top of that turbo so frickin hard. Feels so lethargic on 91, like it's making turbo noises but not doing turbo things... like a loud, yet slow Honda... From that link, I said: "Otherwise the car feels like a beast. It gets up on the turbo so hard it's crazy." pic thread build thread Link to comment Share on other sites More sharing options...
Marvick08GT Posted August 15, 2017 Author Share Posted August 15, 2017 Here is the log, hopefully I did it right. Let me know if you guys need anything different. How does the log correlate to a graph? Thanks guys! Car still runs strong 3rd gear.csv Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 15, 2017 Share Posted August 15, 2017 like a loud, yet slow Honda... ^ouch. Be careful, there may be Honda lovers over here (not me though, nothing against these cars either). Which clutch do you have? Still stock one? Link to comment Share on other sites More sharing options...
Marvick08GT Posted August 15, 2017 Author Share Posted August 15, 2017 ^ouch. Be careful, there may be Honda lovers over here (not me though, nothing against these cars either). Which clutch do you have? Still stock one? Ikr? There is a 780hp s2k that lives a few houses down from me... I'm wrx stage 1 HD exedy with ACT fw Link to comment Share on other sites More sharing options...
rebourne Posted August 15, 2017 Share Posted August 15, 2017 I have a stock clutch. And I currently have a loud, slow Integra. There are plenty of fast loud Hondas, , no offense meant to those. pic thread build thread Link to comment Share on other sites More sharing options...
Rhitter Posted August 15, 2017 Share Posted August 15, 2017 I think this gives a much better picture of how it feels. That reverse swoop in your dyno plot was wonky. Although, I think the numbers have to be 100% ignored. The curve(s) is very similar to the DOM1.5 I posted above. For drive ability I would prefer the line to be a little more vertical below 3k rpms. But probably doesn't actually make a difference in feel. After driving around for a few days how does it feel compared to the 500+ and I think you had a VF52? http://i.imgur.com/wOQCHLJ.png My OBXT build Link to comment Share on other sites More sharing options...
Marvick08GT Posted August 15, 2017 Author Share Posted August 15, 2017 Compared to the x500+ It's definately happier running 21psi. With the plus it would just take off and pull once in boost. Now the car pulls a little better lower end, definately not as effortless as the plus hig7h rpm. I do like the way it sounds No comparison to the vf52, torque comes on a little later but pulls harder and harder as it revs. I think this is a great turbo, not the greatest, but definately above average. They advertise this turbo as a sti replacement (dual avcs) thats good for better spool and torque. I will be keeping this turbo, really not going to work on the car for a while (too sore) we were able to work it out where i didn't lose much. I'm thinking the clutch is not too happy... still holding, but getting squeaky and noisy. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 16, 2017 Share Posted August 16, 2017 I do like the way it sounds So, where is the audio/video clip? After all these plots, tunes and stuff, it's about time to post one no? . Link to comment Share on other sites More sharing options...
Marvick08GT Posted August 16, 2017 Author Share Posted August 16, 2017 So, where is the audio/video clip? After all these plots, tunes and stuff, it's about time to post one no? . How can I post them? What are you guys looking for? Link to comment Share on other sites More sharing options...
WRX USA Posted August 16, 2017 Share Posted August 16, 2017 Post on YouTube and then post the link here. Link to comment Share on other sites More sharing options...
bergs Posted August 16, 2017 Share Posted August 16, 2017 OP is a madman. That is all. Hi Marck! Link to comment Share on other sites More sharing options...
Marvick08GT Posted August 16, 2017 Author Share Posted August 16, 2017 OP is a madman. That is all. Hi Marck! Hey Paul! Yeah, I've mellowed out a lot with age.. Its the German and Irish blood mixing! Car running yet? Link to comment Share on other sites More sharing options...
Gabo Posted August 17, 2017 Share Posted August 17, 2017 VF52 review posted http://legacygt.com/forums/showthread.php/socal-porting-stage-3-vf52-results-264332.html?p=5675032#post5675032 Link to comment Share on other sites More sharing options...
bergs Posted August 18, 2017 Share Posted August 18, 2017 Hey Paul! Yeah, I've mellowed out a lot with age.. Its the German and Irish blood mixing! Car running yet? Had a slight delay getting the turbo to the builder but I'm hoping today I get the call I've been patiently waiting for... Link to comment Share on other sites More sharing options...
