caruolon Posted August 6, 2017 Share Posted August 6, 2017 Hi i have a 2005 Legacy GT I'm looking for an oem, uppipe, downpipe , and main catalytic converter pipe before a catback exhaust would bolt on . It's everything upfront from the turbo to the main cat. I basically need all oem. Where is the best site to get these parts for a cheaper price. Thank you . Link to comment Share on other sites More sharing options...
MilesA Posted August 6, 2017 Share Posted August 6, 2017 Find someone local if you can, you will save on shipping and the seller may cut you a deal since it's less trouble for them. Look for people parting out their cars. Check the For Sale forum here. You can check NASIOC forums since many WRX and STI parts are compatible, just need to make sure they are the correct fit. Craigslist sometimes might have something you can use. Bay of Evil, not always easy to trust someone you don't know if they aren't local, but maybe. Link to comment Share on other sites More sharing options...
WRX USA Posted August 6, 2017 Share Posted August 6, 2017 <---- Filling in your location would be a good first step. As mentioned above there may be some one local to you that is looking to get this stuff out of their garage. Link to comment Share on other sites More sharing options...
MilesA Posted August 6, 2017 Share Posted August 6, 2017 BTW, OP you don't want the original OEM uppipe for '05 or '06 model years. Those have a catalytic converter that Subaru eliminated in later years because it could cause problems. You can run stock tune with the catless OEM uppipe from 07+ LGT or compatible STI. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2017 Share Posted August 6, 2017 I have two stock down pipes, I thought I had the stock up pipe from my 05 but not sure where it is. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
