Jay98LGT Posted August 5, 2017 Share Posted August 5, 2017 After last winter good old Pearl has developed windshield wiper play. There's about 3 inches of free play in the wipers when actuating, but they are still connected so I don't think it's a problem in the transmission, but I don't know. Help?? I'll got take a video and do a quick clip showing what I mean. 2007 Legacy Link to comment Share on other sites More sharing options...
Jay98LGT Posted August 5, 2017 Author Share Posted August 5, 2017 Not sure how to embed it. But link to video showing the play and with the wipers running. Link to comment Share on other sites More sharing options...
relative4 Posted August 6, 2017 Share Posted August 6, 2017 There's a linkage casing between the motor and the arms. Your problem is in there. Pull the arms, remove the cowling, take out the motor & linkage assembly. Repair or preferably replace the linkage, and reassemble. Link to comment Share on other sites More sharing options...
grovlet Posted August 7, 2017 Share Posted August 7, 2017 I had something like that - simple fix 1 - pop off the covers on the connection arm 2 - loosen the nut - probably already loose 3 - lift off the arm and re-position 4 - re-tighten nut 5 - re-install cover Link to comment Share on other sites More sharing options...
relative4 Posted August 7, 2017 Share Posted August 7, 2017 I had something like that - simple fix 1 - pop off the covers on the connection arm 2 - loosen the nut - probably already loose 3 - lift off the arm and re-position 4 - re-tighten nut 5 - re-install coverOP's arms move together. So no, not a loose arm fixing nut. Link to comment Share on other sites More sharing options...
