Jsmith Posted August 4, 2017 Share Posted August 4, 2017 Guys, I have been wondering this for some time now....Does anyone know if the eyesight system stores video? Example being...in the event of airbag deployment, can the video of the incident be recovered through the permanent "dash cams" installed in our vehicles? Link to comment Share on other sites More sharing options...
Learjet45 Posted August 4, 2017 Share Posted August 4, 2017 From the EyeSight manual: https://techinfo.subaru.com/proxy/94763/pdf/ownerManual/094763_2015_Legacy/MSA5M1518DEyeSightSTIS033015_3.pdf EyeSight records and stores the following data when the Pre-Collision Braking System is operated. It does not record conversations or other audio data. - Stereo camera image data - Distance from the vehicle in front - Vehicle speed - Steering wheel turning angle - Lateral movement with regard to the direction of travel - Accelerator pedal operation status - Brake pedal operation status - Select lever position - Odometer reading - Data related to ABS, Vehicle Dynamics Control and Traction Control Function SUBARU and third parties contracted by SUBARU may acquire and use the recorded data for the purpose of vehicle research and development. SUBARU and third parties contracted by SUBARU will not disclose or provide the acquired data to any other third party except under the following conditions. • The vehicle owner has given his/her consent. • The disclosure/provision is based on a court order or other legally enforceable request. • Data that has been modified so that the user and vehicle cannot be identified is provided to a research institution for statistical processing or similar purposes. I can't say if the airbags go off without a pre-collision warning (e.g. t-boned) if it will record that data. But it does seem to store/log some amount of data under certain circumstances. Link to comment Share on other sites More sharing options...
Jsmith Posted August 4, 2017 Author Share Posted August 4, 2017 That's exactly what I was wondering! A normal dash cam facing forward isn't exactly ideal for a t-bone situation either. Thank you for providing the info! Link to comment Share on other sites More sharing options...
