Eugene Onegin Posted July 31, 2017 Share Posted July 31, 2017 Is it really necessary or just a cosmetic thing ? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 7, 2017 Share Posted August 7, 2017 I removed mine a few day's after I bought the car. I bought the car late june 2004, its been off ever since. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MilesA Posted August 8, 2017 Share Posted August 8, 2017 If you have the stock top-mounted intercooler, I think it makes sense to keep it. You'll notice the stock hood scoop has a splitter that channels air through an opening that mates with the top cover (at least mine does). The larger the volume of air flowing through the intercooler, the better it can do its job. The better aftermarket intercoolers have their own custom splitters to direct the air from the scoop. You would have to either trim or remove the engine top cover for those. Link to comment Share on other sites More sharing options...
