xt2005bonbon Posted August 2, 2017 Share Posted August 2, 2017 There should be two wires on the fan connector. The black one should be the ground (goes on the negative terminal of the battery) and the other positive. Just need to figure out a way to hook these two wires to the battery. Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted August 2, 2017 Author Share Posted August 2, 2017 Just did it. Fan works! I think I see the culprit. The plug on the harness side is burnt on one terminal. It looks like that part of the plug can be replaced. But why did it do that??? IMG_20170802_133916933 by kornfan891, on Flickr IMG_20170802_133825151 by kornfan891, on Flickr Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 2, 2017 Share Posted August 2, 2017 Probably had a poor connection there (some play), which in turn created some sparks and then some melting. Maybe it is still usable if you do a good cleaning and make sure the connection becomes snug? Good job btw. Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted August 2, 2017 Author Share Posted August 2, 2017 I just hope its nothing serious! Should I be able to buy just that piece if I need to? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 2, 2017 Share Posted August 2, 2017 I don't think it is anything serious. I think you could. Check junkyards around you too. Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted August 2, 2017 Author Share Posted August 2, 2017 Called the local Subaru Dealer and can't get just the plug. Went to a junkyard and they had an 02 Legacy Sedan and an 01 Forester. Both had e-fan plugs, but they look different. I got one if there's a possibility I can splice this one on. Would that work? Or bad idea? IMG_20170802_165938954 by kornfan891, on Flickr Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 2, 2017 Share Posted August 2, 2017 Just cut the bad plug wires, solder the new to you plug wires, use some wire heat shrink wrapping and whatever else to protect the wires from the elements, and done. Link to comment Share on other sites More sharing options...
05LegacyGTGa Posted August 3, 2017 Author Share Posted August 3, 2017 It's alive! I did my best to make it look like nothing was ever touched, ha. I don't think it looks too bad! IMG_20170802_185617867 by kornfan891, on Flickr IMG_20170802_185706889 by kornfan891, on Flickr IMG_20170802_185648875 by kornfan891, on Flickr Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 3, 2017 Share Posted August 3, 2017 Congrats! Link to comment Share on other sites More sharing options...
