Officerdonkdonk Posted July 23, 2017 Share Posted July 23, 2017 Decided to pull out my housing to diagnose all the slop i have while in gear. To my wonderment, i noticed the ball is heavy caked in old grease and outside it is covered in debris. Pictures are after partial cleaning! My quick questions 1.) What is the plastic piece that sits on the ball called ( I thought it was a shift rod bushing?) 2.) How much grease (if any) is actually needed Link to comment Share on other sites More sharing options...
compsurge Posted July 23, 2017 Share Posted July 23, 2017 Oh this fun. I wasn't able to find the part number when I had this issue. They wanted to sell the entire assembly. I believe the spring clip popped out of the retaining groove. If you can bend it a little outwards (into a larger circle), then place it back in the original location. I put a new O-ring on it (you appear to be missing one at the base) and some grease and put it back together. Buy an assortment at Harbor Freight if you have one nearby. If the Nylon part is damaged (I can't tell if yours is), I'd consider printing a replacement part. http://opposedforces.com/parts/legacy/us_b13/type_27/manipulation/manual_gear_shift_system/ Link to comment Share on other sites More sharing options...
MilesA Posted July 23, 2017 Share Posted July 23, 2017 Was that cir-clip engaged in the groove at the top of the socket? If it not, you would have a lot of slop. Otherwise, some of your other shifter bushings may be shot. Something like this could help: https://www.summitracing.com/parts/ens-19-1102g/applications/year/2005 BTW, the ball and socket should just be packed with grease, no reason not to. Link to comment Share on other sites More sharing options...
rhino6303 Posted July 24, 2017 Share Posted July 24, 2017 Decided to pull out my housing to diagnose all the slop i have while in gear. To my wonderment, i noticed the ball is heavy caked in old grease and outside it is covered in debris. Pictures are after partial cleaning! My quick questions 1.) What is the plastic piece that sits on the ball called ( I thought it was a shift rod bushing?) 2.) How much grease (if any) is actually needed I just ordered the cage (bushing), orings and a new snap ring. It definitely helped with slop. I do already have all other shift bushings. Here are the part numbers you need; they are fairly cheap as well. 031432000 SNAP RING-INNER 1 062620280 O-RING 2 35035KA010BUSHING 1 Link to comment Share on other sites More sharing options...
Officerdonkdonk Posted July 24, 2017 Author Share Posted July 24, 2017 Was that cir-clip engaged in the groove at the top of the socket? If it not, you would have a lot of slop. Otherwise, some of your other shifter bushings may be shot. Something like this could help: https://www.summitracing.com/parts/ens-19-1102g/applications/year/2005 BTW, the ball and socket should just be packed with grease, no reason not to. C clip was engaged before pulling out. second O ring is still in the socket. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 24, 2017 Share Posted July 24, 2017 Make sure the bolts are tight on the bottom of the shifter too, where it bolts to the tranny. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
