Clunking when turning under power
Hey guys, first time poster long time reader and have seen a post to help me out yet. so my problem is when i turn right under power i have a clunking the sounds similer to a bad cv axle but recently replaced with both fronts from raxles(was highly recommended in one of the forums), new moog wheel bearings and just had new sway bar end links replaced at a local shop but the didnt notice the clicking/clunking noise. Should i take another look at the wheel bearing or is there something else i should look at? :confused:
Found another thread where a guy had the same issue and had a bad transmission mount so I ordered a new mount for tranny and group N engine mounts,
Cruise was working till I put on a catless up pipe but have the resistors on the way to fix the cel/ blinking crude control light
Your the first one I've heard of that has Moog front wheel bearings and CC works. Back in the day, CC would surge a little and then fail. We replaced the Moog's with OEM or one of the other two recommended brands and CC worked fine after that.
May be Moog fixed that issue...
Engine Build - Click Here
I have the same thing happen with my car in the winter. My grandfather (mechanic) says it is likely due to grease freezing up and not moving very well (I Live in Manitoba where it gets to -45 celcius)
If its not cold where you are. likely something mechanical.
Hope you figure this out
I saw that people had the issue and ordered Timkin wheel bearings but didn't put them in yet
Back in the day. I removed the Moog and returned it. got my $140. back and paid $128 for an OEM.
I just put a Timken in the left front earlier this year.
Hey guys, got the the mounts put on today and looks like it fixed the problem. Did the rallitek race insert and that alone fixed the cv noise while turning under power but adds a decent amount of NVH but from what I've read about the insert it will get better over time
