Officerdonkdonk Posted July 21, 2017 Share Posted July 21, 2017 First, I would like to introduce myself. 26, male, Navy, never owned a Subaru. Daily: 03 esclade ($10,000 5 years ago) 1st project: 240sx drift car (Sold for parts because i was a nub (Non Useful Body) and didnt know what job i got myself into. Intentions: Flip for profit or fall in love. I Have been looking through this forum for a couple of weeks now to help me decide if this project was worth taking. Then I drank a bottle of vanilla Crown and bought the car. 2005 Legacy 2.5 GT Limited 5MT. Problems: [CEbTER]Blown clutch and flywheel. [Replaced] Axels cracked. [Replaced] Dead battery [Replaced] supposed electrical ground. supect: radio cd changer. (Keeps cycling after car is turned off) Paint, paint, paint [Plasti dip in progress] Interior/ exterior trim [nope] Insane amount of play in stick shift [waiting for bushing] tail light and rear bumper damage [light ordered, maybe sand and heat gun pop out] Headlight oxidation [im too lazy for this right now] Master Window switch sucks [Looking for quality replacement] Glovebox also sucks [super sucks] Brakes and rotors seen better days Weird noise from around the trans after acceleration Noise happens in gear and moving. The sound is coming from under the shifter. sounds like small backfire, but only through to the cat or it sounds like the tranny is bouncing on the mount. request if this is a problem that someone has delt with before. Thanks for the further help and hope I fix this car proper.[/center] Link to comment Share on other sites More sharing options...
Max Capacity Posted July 21, 2017 Share Posted July 21, 2017 Get under the car with a good flash light and check things out I just replaced all calipers on both my cars with calipers from NAPA easy job with a helper to bleed the brakes You may have an exhaust leak... oh here,http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Officerdonkdonk Posted July 21, 2017 Author Share Posted July 21, 2017 Get under the car with a good flash light and check things out I just replaced all calipers on both my cars with calipers from NAPA easy job with a helper to bleed the brakes You may have an exhaust leak... oh here,http://people.csail.mit.edu/ilh/vacation/ Dude, thank you! I was looking for that. Going under the car later today when my buddy gets home. Took a video, wanna see if anyone else had the same problem or similar. I am done driving it until we find this out. https://www.youtube.com/watch?v=75dP-G0hVLQ&feature=youtu.be Link to comment Share on other sites More sharing options...
Officerdonkdonk Posted July 21, 2017 Author Share Posted July 21, 2017 Also debating on what to do with this boost gauge/ trim setup As you can tell, the top part of the trim is broken off and the gauge housing looks like a 10 year old's science fair project that he procrastinated about and ended up with a C- Any opinion on what i should do? I am honestly lost with this one... Link to comment Share on other sites More sharing options...
Officerdonkdonk Posted July 22, 2017 Author Share Posted July 22, 2017 Headlight Restore sanding from 400 grit to 2000 Then clearcoat (waiting till tomorrow to polish out the orangepeel) Link to comment Share on other sites More sharing options...
Officerdonkdonk Posted July 23, 2017 Author Share Posted July 23, 2017 **** this bitch! Easy swap though Link to comment Share on other sites More sharing options...
