aportis72 Posted July 20, 2017 Share Posted July 20, 2017 Hi everyone. I recently had new tires installed. I noticed the rear inside edge was worn pretty bad on the old tires. So I had an alignment done after the new tires were installed. Les Schwab told me that there was no toe adjustment on the rear on my car. He said he did the bet he could whatever that means. I took the paperwork and went home but then started doing some research. Looks like there's no camber adjustment in the rear. My car is lowered I forget the brand of suspension. Here is the print out let me know what you think. Thank you Austin http://i65.tinypic.com/152gbqv.jpg Link to comment Share on other sites More sharing options...
RustyRuu Posted July 20, 2017 Share Posted July 20, 2017 I could not view your photo bucket but there is a toe adjustment on the rear. It's adjusted by two bolts on the inner subframe by your differential. Those bolt part numbers are 901700122 if you want to look them up. Unfortunately these bolts get seized a lot which is what they probably ment by did the best they could. Camber is not adjustable in the rear without some additional parts you are hopefully around or under 2 degrees of negative camber. Link to comment Share on other sites More sharing options...
FJuan Posted July 20, 2017 Share Posted July 20, 2017 What year is your car? A few aftermarket companies make rear camber adjustment parts for our cars, depending on your year. This will also help correct your toe in/out issue. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
aportis72 Posted July 20, 2017 Author Share Posted July 20, 2017 Sorry got the photo fixed dang Photobucket up now. Car is a 2009 legacy GT Secp B Link to comment Share on other sites More sharing options...
apexi Posted July 21, 2017 Share Posted July 21, 2017 I hope you don't mind if i do this, just to make things easier for people to read Link to comment Share on other sites More sharing options...
aportis72 Posted July 22, 2017 Author Share Posted July 22, 2017 Thank you. Also I looked up my suspension RCE T1 coilovers and also have a Whiteline adjustable rear sway bar. Don't know if that is helpful. Thanks again. Link to comment Share on other sites More sharing options...
aportis72 Posted July 25, 2017 Author Share Posted July 25, 2017 Do my numbers look okay? Link to comment Share on other sites More sharing options...
FJuan Posted July 25, 2017 Share Posted July 25, 2017 Fronts look good, but the right rear may show signs of wear on the inside in about 6 - 12 months due to the camber setings, but it's not that far off from spec though. Make sure to rotate every 5k miles to keep them even. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
