doublechaz Posted July 15, 2017 Share Posted July 15, 2017 I just picked up from the dealer an oil pickup. I also have one out of a spare engine. My question/problem is that they are different. The one the dealer gave me for my 95 ej22 is a tube with a round end capped with screen. The one I have from the spare engine also an ej22 is mostly the same, but it has a brace that runs to one of the windage tray bolts. So did the dealer give me a wrong part, or is that spare a newer engine that added a brace? The ones I see online all have a brace, but they don't have solid info on whether they cross from ej25 to ej22. I got rained out so I don't know what the pickup currently installed looks like. I'm pretty sure I want to run one with a brace given all the talk about them cracking, but only if it is a correct fit. Link to comment Share on other sites More sharing options...
Setnev Posted July 16, 2017 Share Posted July 16, 2017 Newer ones added a brace. The old ones used to crack from normal sloshing back and forth and cause terminal oil starvation. In fact, Killer B Motorsports was the first one (that I know of) to offer a revised and braced oil pickup tube for the EJ series motors. The fact that Subaru caught on to this revision makes it seem like they were definitely listening. Link to comment Share on other sites More sharing options...
doublechaz Posted July 16, 2017 Author Share Posted July 16, 2017 So the ej25 braced pickup is a fit in the ej22 as far as gap to the bottom of the sump and bolt pattern? I'll put in my braced unit, and then when I build the motor that donated it I'll either get an after market, or tell the dealer I have a newer car so I get the right thing. Thanks. Link to comment Share on other sites More sharing options...
twisty Posted July 17, 2017 Share Posted July 17, 2017 my 96 ej25 has this one stock, is it the same as the one youre talking about? http://i57.tinypic.com/kbopxt.jpg Link to comment Share on other sites More sharing options...
Thor294 Posted July 17, 2017 Share Posted July 17, 2017 Newer ones added a brace. The old ones used to crack from normal sloshing back and forth and cause terminal oil starvation. In fact, Killer B Motorsports was the first one (that I know of) to offer a revised and braced oil pickup tube for the EJ series motors. The fact that Subaru caught on to this revision makes it seem like they were definitely listening. interesting. so what years did they add the brace? Link to comment Share on other sites More sharing options...
Brighton96 Posted July 17, 2017 Share Posted July 17, 2017 My 96 2.2 has the braced filler pick up too, and my motor was built in November of 95 Link to comment Share on other sites More sharing options...
Setnev Posted July 17, 2017 Share Posted July 17, 2017 The mounting style looks hit or miss on all EJ's alike. I have found no brace in the older EJ22's up to early 95, when it looks like they switched to this style: http://i.imgur.com/RjtRktJ.jpg Then in 98 they switched to this: http://i.imgur.com/Pzs0odF.jpg Link to comment Share on other sites More sharing options...
doublechaz Posted July 18, 2017 Author Share Posted July 18, 2017 Twisty's pic looks like the spare I took out. Setnev's top diagram part 16 is what I bought. I don't know what's in my daily until I get in there, but I think mine is a mid 95 build. Perhaps it has that other crap in there to brace it, or perhaps not. It's been near on 10 years since I've had the pan off. I hope what I'm having is pickup leak, but it's probably worn bearings given how I drive. Link to comment Share on other sites More sharing options...
doublechaz Posted July 24, 2017 Author Share Posted July 24, 2017 Bad news is there doesn't seem to be any problem with my pickup. Looks like the reason for my low pressure starts was the drain back having a bad seal (item 17 in the diagram) so that the system could empty out while sitting. So I don't know if 100k+ of low pressure starts or 100k of my driving is the problem, but my low idle pressure is probably here to stay. Link to comment Share on other sites More sharing options...
