jfg22557 Posted July 8, 2017 Share Posted July 8, 2017 I'm doing a complete rear brake overhaul, including the parking brake shoes and assembly (currently 125k on the clock). Does anyone know the part numbers for the rear parking brake assembly components? I'm trying to find a diagram with part numbers for the return springs, adjuster, etc.. but have not had any luck. The diagram in the vacation pics (below) does not list part numbers. http://i731.photobucket.com/albums/ww312/jfg22557/Screen%20shot%202017-07-08%20at%206.18.07%20PM_zpsou7rlrms.png Rock Auto has the kit from third party manufacturers (see pic below), but I'd prefer OEM unless someone has used one of these without issue. http://i731.photobucket.com/albums/ww312/jfg22557/Screen%20shot%202017-07-08%20at%206.21.21%20PM_zpsezbd50st.png Thanks Link to comment Share on other sites More sharing options...
08SpecB_DE Posted July 8, 2017 Share Posted July 8, 2017 The aftermarket kit will do just fine. No need to spend 3x as much for oem. Link to comment Share on other sites More sharing options...
apexi Posted July 8, 2017 Share Posted July 8, 2017 I use http://parts.subaru.com to get part numbers. Link to comment Share on other sites More sharing options...
jfg22557 Posted July 11, 2017 Author Share Posted July 11, 2017 I use http://parts.subaru.com to get part numbers. Completely forgot about that website, thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted July 11, 2017 Share Posted July 11, 2017 Completely forgot about that website, thanks! As well as this sticky...http://legacygt.com/forums/showthread.php/oem-online-subaru-parts-vendors-list-42243.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jfg22557 Posted July 11, 2017 Author Share Posted July 11, 2017 As well as this sticky...http://legacygt.com/forums/showthread.php/oem-online-subaru-parts-vendors-list-42243.html Did see that, but most of the OEM distributor (dealership) parts websites use the same diagram that I found in the vacation pics, which does not contain part numbers. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 11, 2017 Share Posted July 11, 2017 Did see that, but most of the OEM distributor (dealership) parts websites use the same diagram that I found in the vacation pics, which does not contain part numbers. Have you looked recently, most list the oem part numbers and 25% off. Got to post 171 in that thread. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jfg22557 Posted July 11, 2017 Author Share Posted July 11, 2017 Have you looked recently, most list the oem part numbers and 25% off. Got to post 171 in that thread. Thanks for the heads up! Will be pming them Link to comment Share on other sites More sharing options...
