scooby-doo subaru Posted July 8, 2017 Share Posted July 8, 2017 I am having a problem where my rotor is getting a groove dug into it by the caliper bracket bolt. I have went through countless brake pads and rotors about 3 rotors a month. And a set of pads a week. I have bought a new caliper. Bracket. And rotor 2 days ago and the rotor and caliper bracket are completely shot. I've had the inner and outer tie rods done. Ball joint. Wheel hub bushing. When I turn my car hard to the right I get an unbelievable grinding and crunching sound and it brings my car to a complete stop. Even in reverse. The vehicle is a 2000 subaru legacy L. Link to comment Share on other sites More sharing options...
Setnev Posted July 10, 2017 Share Posted July 10, 2017 Holy crap batman! Pads once a week. Autozone must love your business! My first instinct would be to say the bearing is shot, but you stated you had it replaced. I'd put the front of the car up on jack stands, take off the front tire, turn the steering wheel all the way to the right and rotate the hub assembly. Also, check to see that there is no lateral or vertical play in the steering knuckle or wheel hub assembly. It sounds like the retainer clip for the bearing isn't there and/or the axle nut isn't tightened causing the whole hub assembly to come loose. Link to comment Share on other sites More sharing options...
RumbleRumble Posted July 11, 2017 Share Posted July 11, 2017 Yeah sounds like the hub is sliding. Can't say for sure since I can't see. Take some pics. Link to comment Share on other sites More sharing options...
scooby-doo subaru Posted July 14, 2017 Author Share Posted July 14, 2017 I will try to take pics but I cannot figure out for the life of me how to upload them from my phone onto here Link to comment Share on other sites More sharing options...
Setnev Posted July 16, 2017 Share Posted July 16, 2017 Get the Imgur app on your phone and get the sharable link and post it Link to comment Share on other sites More sharing options...
