Above_Bored Posted July 6, 2017 Share Posted July 6, 2017 So. I really need some help here. My 07 2.5i developed an exhaust leak... I replaced the front pipes/cat with a Walker 16564 pipe/cat setup. Unboxing it, I found a small burr on the manifold flange face- probably welding slag from shitty welds- which I shaved down with a file. Installing it, the angles are just a hair off on the flanges, so things don't line up perfectly. I had to twist the pipes a touch to get it aligned. It went on, and we started the car- nope, another leak under the heat shielding behind the front flange on the rear cat pipe. Replaced THAT with a Walker 55585 rear cat. Ok, we're good now, right? NOPE. It's leaking at the passenger side manifold flange, just a hair. It's enough to cause acceleration issues, and I have a P0301 code for the O2 sensor along with a distinct leak knocking sound on acceleration. My question is, what can I replace the front cat/pipe with, in the $300 range, that won't be a massive PITA like this has been? Given the lack of quality control from the Walker parts, I'm not going with them again. I can't afford the OEM parts... suggestions? Thanks. I'm sick of putting needless money into this. The last two years have been a nightmare. But, more on that later. Link to comment Share on other sites More sharing options...
solidxsnake Posted July 6, 2017 Share Posted July 6, 2017 Junkyard an OEM part? Have the leak repaired at an exhaust shop? Link to comment Share on other sites More sharing options...
Above_Bored Posted July 6, 2017 Author Share Posted July 6, 2017 Junkyard an OEM part? Have the leak repaired at an exhaust shop? Well, yeah, I "could" do that... I'm not sure what I was hoping I'd get for an answer.... magic? I'd like to replace with new parts, since it's my daily driver and I can't really afford a shop. I've spent a metric ton of money on the car already due to shitty work and poor diagnoses. Link to comment Share on other sites More sharing options...
