Surfcast23 Posted July 3, 2017 Share Posted July 3, 2017 Hello all, I am about to install the AVO S1X03E1GV001T +0.50 Caster Adjustment Bushing kit amd wanted to ask if there is anything that needs to be done differently when I take It to be aligned. Or so they just use the factory specs. Thanks Link to comment Share on other sites More sharing options...
Marvick08GT Posted July 3, 2017 Share Posted July 3, 2017 There aren't any caster adjustments. That's why you use the bushings Link to comment Share on other sites More sharing options...
sanchitosonria Posted July 13, 2017 Share Posted July 13, 2017 I believe you want as much negative camber as you can while maintaining 0 degrees toe. Link to comment Share on other sites More sharing options...
MilesA Posted July 13, 2017 Share Posted July 13, 2017 Stock caster is fixed, so they won't try to adjust it unless you let them know it's possible. The intent is to add as much caster as the bushings will allow while making sure both sides are equal. Link to comment Share on other sites More sharing options...
