6MT Shift Lengths
I figured I might as well document the shift lengths since I have 3 different shifter combinations. Maybe somebody else can help fill in the rest in of the combinations. [ I actually am kind of curious as what are the shift lengths for WRX STS with a short shift adapter.]
I put a ruler under the hazard light and measured to the middle of the shift pattern on the knob. I know that this doesn't given exact geometric shift length but it does have consistent point to measure from. I did make sure that picture measurement matched what i thought the actual measure meant is (The picture angle an affect the measurement, I even went back to take an extra picture to correct it, because one of them didn't match)
I did measurements for 3rd gear, neutral and 4th gear
Legacy STI STS Accessory Shifter
3rd Gear 3 3/4"
Neutral 6 3/16"
4th Gear 8 1/4"
3rd gear is 2 7/16" throw from neutral
4th gear is 2 1/16" throw from neutral
3-4th shift is 4 1/2"
Legacy STI STS Accessory Shifter with Boomba short throw adapter (30% reduction advertised)
3rd Gear 5"
Neutral 6 1/2"
4th Gear 7 3/4"
3rd gear is 1 1/2" throw from neutral
4th gear is 1 1/4" throw from neutral
3-4th shift is 2 3/4"
Are you sure you don't also have the boomba stick?
Sent from my SAMSUNG-SM-G920A using Tapatalk
I am positive that I don't. It's the same height as stock and STS accessory. It's just the angle (or lack of angle) of the pictures.
I feel like the awesomeness of the boomba weighted short throw adapter cannot be overstated. The unweighted equivalents are garbage by comparison.
The combination of the boomba weighted adaptor plus a heavy knob plus Redline lightweight shockproof made my trans/shifter feel notably better than a new MX-5. And if that doesn't say something, I don't know what does.
By better, I mean smoother yet crisper shifts, and shorter but accurate feeling motion.
Sent from my ASUS_Z012DC using Tapatalk
I wanted to add my shift lengths for comparison. I have the boomba stick and ssa, I removed the knob because it is very long. To give a relevant measurement. Looks like around a 2 1/4" throw from 3 to 4.
feb25c3b5e636986f5463affabd80e0d.jpg686fd868d1b22184f50f5f92934a3608.jpg2e415dde555e16821093be0aea18dbcb.jpg
