05 LGT Automatic - Stalling issues when coming to a stop
Hey everyone, made a thread about this maybe a few months ago, everything was fine and it started up again. So basically I have an automatic LGT, and when I come to a stop for example a red light or stop light, or if I've been stopped and the light turns green and I just let off the gas to roll into the intersection for a left turn, sometimes (and quite randomly, hard to reproduce so I haven't been able to get a shop to actually see what I mean) the car would shudder or shake, some of the dash lights would come on, the headlights would flicker, and the car would threaten to stall out. If I hit the gas, or hit the brakes, the RPMs catch and bounce back to normal idle RPM, but if I don't do anything it'll eventually stall out.
I've changed the battery, checked ATF levels (though I plan on changing the ATF sooner rather than later just in case), and to the best of my ability checked hoses for cracks that might suggest a vacuum leak. Also cleaned the TB maybe 5000km ago, and I cleaned the MAF recently as well. Unfortunately I'm quite useless when it comes to cars, and I haven't attempted to check out the fuel filter, or find a way to check the torque converter, etc. No check engine lights at all, and scanning with my OBD2 tool shows no codes.
Anyone have any ideas on how to proceed? I want to take it into a Subaru-specialized shop that a bunch of my friends and local forum members recommend, but I don't know how to tell them or show them the issue since it's so random, and I can go many days without it happening, or it happens multiple times a day!
Thank you so much everyone!
Edit: if it is the torque converter, how does one "check" if it's good? Also I tried to find the DACCO SU19 stock T.C and everywhere seems to be out of stock, I just put in a notification on RockAuto but even eBay, etc. don't have it. Closest I found was the IPT aftermarket high stall one for a cool $638 :(
This is just a sort of list I've been keeping but it seems very daunting to a noob like me!
ATF change
Vacuum leak
Idle air control valve
Torque converter
Fuel filter
O2 sensor
Spark plugs
When mine did that, it was a vacuum hose leak. I actually had two, one was behind the alternator under the intake, and the other was related to the blue tee under the intercooler/intake on the back of the engine. After 12 years the rubber gets hard and brittle and has trouble holding a seal. Recommend starting down the path of replacing a number of the vacuum lines.
I'm truly hoping it's just a vacuum leak, everything else seems pretty pricy! Once again since I'm basically useless when it comes to cars, is there a site or list of hoses that I could buy, take to a shop and have them change the hoses? Or should I just take it in, let them inspect it for leaks, and have them tell me what hoses to buy/order them for me (I'm sure there will be a mark up but I guess better than me trying to find the right hose?)
Thanks Infosecdad!!
  • I Donated Too
make a homemade boost leak cap/tester... I made one, it has been VERY handy and I have even used a cheap 12v tire pump to get pressure in it so I don't have to wake up the big boy compressor.
Have you cleaned the MAF sensor ?
The boost leak test was my first idea...but someone all ready beat me to it....;)
I clean my MAf once a air when I clean K&N air filter.
Another idea, what do your engine ground cables look like, have they been replaced ?
Engine Build - Click Here
Thank you for the suggestions everyone! I cleaned the MAF a few months ago but I guess it doesn't hurt to do it again. The boost leak, engine ground cables, vacuum leak and maybe spark plugs I'll probably let the shop take a look at it I guess, don't trust my own incompetence haha! But at least now I have a list of things I can get them to look at specifically for me! Also sucks there aren't any engine codes at all!
Thanks all!
So today it threw P0302 and P0304, misfires in 2 and 4. Definitely bringing the car in asap to get it checked out, hoping it's just sparks or something.
I cleared the code and they haven't returned though.
Hoping this code is related to the stalling, would suck to have two problems..
My bet is the intake o ring seals.
Sent from my SM-G930P using Tapatalk
That's normally a cold weather thing, but worth looking into. The O-rings are about $25.00
You'll need to lift the intake a bit to replace them. I did mine without removing the intake just un-bolt a few items as needed.
I had shuddering and stalling symptoms this year but codes did appear. The first was an OCV Oil Control Valve over-advance caused by a piece of silicone sealer that migrated from somewhere. And recently a Camshaft Position Sensor. Each fault had its own specific code, but months earlier all I saw were random misfire codes. I'd check for vacuum leak and the PCV hoses under the IC.
JC, Chicagoland bassist & opentracker
2005 LGT 5MT Ltd wagon
2005 LGT 5MT Ltd sedan
