06SubLegTx Posted June 29, 2017 Share Posted June 29, 2017 Hello, I have a 06 Legacy with a engine splash shield that is only a couple of months old and it is already starting to sag on the Driver Side where there is less plastic material. Has anyone ever found a way to brace it up or modify it so that it's not sagging like it's many years old when it is only 6 to 9 months? Thanks for and constructive input. Link to comment Share on other sites More sharing options...
cseagle08 Posted June 29, 2017 Share Posted June 29, 2017 I'd suggest zip-ties? No one will see it and it'll be easily removable if you ever need to. My '05 the splash shield has been missing since I bought it, lol. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 29, 2017 Share Posted June 29, 2017 The shield is said to help create a low pressure area under/behind the tmic. You want to have it in place. The top engine is said to help too...but I removed mine back in Jul 04 a couple weeks after I bought my wagon. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
