st7era Posted June 28, 2017 Share Posted June 28, 2017 The left side of my engine bay creates a light white smoke at times, not sure exactly what it is but it gives off a oil/ antifreeze smell. With that being said I filled my antifreeze a month ago when I got my car and it was near empty, issues? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted June 28, 2017 Share Posted June 28, 2017 is it a 2.5i ? If so, have the coolant system pressure tested for a leak. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
st7era Posted June 29, 2017 Author Share Posted June 29, 2017 is it a 2.5i ? If so, have the coolant system pressure tested for a leak. Yes It is a 2.5i! Definitely going to do this, i've noticed a pipe that looks like something is dripping on it but I can't seem to find where its coming from, definitely thinking its a coolant system leak of some sort planning on taking a trip to the mechanic soon, thanks! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
