RochesterCanuck Posted June 25, 2017 Share Posted June 25, 2017 This might be a really stupid question, but here goes: I bought a replacement OEM thermostat, and when I go to replace it, it doesn't stick in the water pump. I am using a new gasket, and it just falls out every time. Any one know what's going on? This is driving me nuts. (Yes, I am putting it in the right way) Link to comment Share on other sites More sharing options...
RustyRuu Posted June 26, 2017 Share Posted June 26, 2017 i'm pretty sure that's about right it forms to the space after being torqued down and gets stuck in there after many heat cycles. I will let you know tonight or tomorrow though since I am replacing my t stat tonight for an oem one. my new oem one came with a new seal/gasket installed on it (tstat) already. do you know which water pump brand you have? Link to comment Share on other sites More sharing options...
RustyRuu Posted June 26, 2017 Share Posted June 26, 2017 i would say just run with it and you'll find out if its working, pretty quick after you begin bleedg the cooling system, and you can even use water first to see if its working properly if you dont think so. Link to comment Share on other sites More sharing options...
RochesterCanuck Posted June 26, 2017 Author Share Posted June 26, 2017 I ended up using the gasket from the old thermostat. I know you should change it, but it actually looked identical to the new one. Surprisingly, replacing that thermostat was the hardest part of my day (replacing thermo, radiator, and all hoses). Link to comment Share on other sites More sharing options...
