Skeen Posted June 22, 2017 Share Posted June 22, 2017 Howdy, Is there any way to replace this rubber/rubber coated metal piece on the back doors? I've looked around the forums and haven't been able to find any solid answer on my question. The car is a 2005 2.5i Sedan, but I've seen this same thing starting to happen on my '09 Outback as well. It gets rather annoying to have to grab the loose rubber piece and hold it so it does not get shut in the door. Link to comment Share on other sites More sharing options...
KRM Posted June 22, 2017 Share Posted June 22, 2017 Did mine in an hr. Remove door panel, locate retaining screws, loosen the window glass retainers/possibly remove it all together, use a long skinny screwdriver up inside the door to release the clips. and reverse process to install. Not really hard to do. Sorry, I don't think pictures are necessary. It's pretty straight forward Link to comment Share on other sites More sharing options...
Skeen Posted June 22, 2017 Author Share Posted June 22, 2017 Did mine in an hr. Remove door panel, locate retaining screws, loosen the window glass retainers/possibly remove it all together, use a long skinny screwdriver up inside the door to release the clips. and reverse process to install. Not really hard to do. Sorry, I don't think pictures are necessary. It's pretty straight forward No apologies needed! Thanks a ton! Any idea what the part number is for this piece? Link to comment Share on other sites More sharing options...
KRM Posted June 23, 2017 Share Posted June 23, 2017 61280AG031 I think this one is for the rear left door. Link to comment Share on other sites More sharing options...
Skeen Posted June 28, 2017 Author Share Posted June 28, 2017 61280AG031 I think this one is for the rear left door. Thank you! Link to comment Share on other sites More sharing options...
rapture Posted June 28, 2017 Share Posted June 28, 2017 Theres always plasti dip Link to comment Share on other sites More sharing options...
zactek Posted June 28, 2017 Share Posted June 28, 2017 I used a silicone weatherproof glue to glue it from the underside,been holding for a few years. Make sure to use a generous amount. Zack K. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 29, 2017 Share Posted June 29, 2017 I replaced that horizontal piece years ago may be in 08 or 09 and did a thread on here about it with pictures. OP are you asking about that or the vertical strip ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Pazuzu Posted July 1, 2017 Share Posted July 1, 2017 Check this out Sent from my SM-G930P using Tapatalk Link to comment Share on other sites More sharing options...
csaari Posted July 1, 2017 Share Posted July 1, 2017 I've replaced those pieces on all four doors of my '05. They're usually referred to as Belt Moldings or Belt Weatherstripping. Very easy to do without taking off the door panel, took me probably 5 or 10 minutes per door. I did manage to drop a screw down inside one of the doors. Got lucky... the magnet on the speaker caught it, and I was able to fish it out with a telescoping magnetic tool. I don't have any pics handy, but these 2 posts do a good job explaining the process: http://legacygt.com/forums/showpost.php?p=2338479&postcount=42 http://legacygt.com/forums/showpost.php?p=2543525&postcount=59 (Thanks, Max! I couldn't find your pics, though.) I'll be glad to take some pics tomorrow showing where the screws are. And here's what I have for the part numbers. I believe they're good for 2005-2009 Legacy and Outback. Belt Weather-Strip Passengers Side Front Door Part Number: 61280AG021 Belt Weather-Strip Drivers Side Front Door Part Number: 61280AG031 Belt Weather-Strip Passengers Side Rear Door Part Number: 62280AG001 Belt Weather-Strip Drivers Side Rear Door Part Number: 62280AG011 Link to comment Share on other sites More sharing options...
Max Capacity Posted July 1, 2017 Share Posted July 1, 2017 Great youtube video there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Pazuzu Posted July 2, 2017 Share Posted July 2, 2017 Great youtube video there. Yeah i thought so Sent from my SM-G930P using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted July 3, 2017 Share Posted July 3, 2017 Yeah i thought so Sent from my SM-G930P using Tapatalk It showed me how easy it is to replace the door handle grips. I just ordered a pair. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Skeen Posted July 3, 2017 Author Share Posted July 3, 2017 Theres always plasti dip True, not quite what I was looking for though. I replaced that horizontal piece years ago may be in 08 or 09 and did a thread on here about it with pictures. OP are you asking about that or the vertical strip ? No, I am looking to replace the horizontal strip. Check this out Sent from my SM-G930P using Tapatalk Wonderful Video! This is exactly what I needed. I've replaced those pieces on all four doors of my '05. They're usually referred to as Belt Moldings or Belt Weatherstripping. Very easy to do without taking off the door panel, took me probably 5 or 10 minutes per door. I did manage to drop a screw down inside one of the doors. Got lucky... the magnet on the speaker caught it, and I was able to fish it out with a telescoping magnetic tool. I don't have any pics handy, but these 2 posts do a good job explaining the process: http://legacygt.com/forums/showpost.php?p=2338479&postcount=42 http://legacygt.com/forums/showpost.php?p=2543525&postcount=59 (Thanks, Max! I couldn't find your pics, though.) I'll be glad to take some pics tomorrow showing where the screws are. And here's what I have for the part numbers. I believe they're good for 2005-2009 Legacy and Outback. Belt Weather-Strip Passengers Side Front Door Part Number: 61280AG021 Belt Weather-Strip Drivers Side Front Door Part Number: 61280AG031 Belt Weather-Strip Passengers Side Rear Door Part Number: 62280AG001 Belt Weather-Strip Drivers Side Rear Door Part Number: 62280AG011 Very Helpful, thank you! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 3, 2017 Share Posted July 3, 2017 What I hate is the price though. This thing is not cheap . Mine are not split but the black plastic cover is cracked in many places. I did not think about plasti dip though. That might work... Link to comment Share on other sites More sharing options...
rapture Posted July 5, 2017 Share Posted July 5, 2017 Yeah if its just the black flaking off id go with plastidip But if the rubber is seperating and causeing other issues might have to replace Def check locally tho Might find a used decent one Link to comment Share on other sites More sharing options...
Max Capacity Posted July 5, 2017 Share Posted July 5, 2017 Skeen, my picture just show where I was able to push the rubber on both ends around a bit and get a screw driver on the end screws, I didn't remove the door cards. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
