VaR Posted June 22, 2017 Share Posted June 22, 2017 So let's start like this.. driving home my lego stutterd and stalled out (5eat). checked my ap and it said cyld 1 misfire, so I swapped coil and plug from #1 with number 2, and reset ecu. So ruff idle and code popped up for cyldr 4 so wtf... so called my friend at brokenmotorsports and he said check ground so while checking around I found the brown harness connector that sits over the trans half melted from sitting next to the exhaust housing of the turbo. and now am getting a code for running to rich(11.xxx at idle) and a maf code. any1 have this issue b4? and have a leadon where I can get this connector asap?? Link to comment Share on other sites More sharing options...
MilesA Posted June 22, 2017 Share Posted June 22, 2017 Are you sure on the cylinder numbering, it is different from many other cars: 1 - Passenger F 2 - Driver F 3 - Passenger R 4 - Driver R Suggest you focus on isolating and fixing the misfire first. Do you have turbo heat shields installed? Check here for tech service info, may be useful. http://legacygt.com/forums/showthread.php/vacation-pix-171435.html Hope that helps. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 22, 2017 Share Posted June 22, 2017 A junkyard may be a good place to get a connector. If your close to http://www.AZPinstalls.com check with them, Mike or Rey may be able to help you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
VaR Posted June 23, 2017 Author Share Posted June 23, 2017 so after poking stabbing and pacing around I think I've found my problem, might be my maf. how u say? well while I had the car on and idling like shit I started tugging at the tip(lol) and tapped at the maf and the freaking idle returned to normal. so I kept tapping and smacking it then the idle went back to shit. so did it again till it returnd to normal. among other things I found my waste gate arm was no longer attached to the waste gate elbow.. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 23, 2017 Share Posted June 23, 2017 Looks like you found some things to fix. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MilesA Posted June 23, 2017 Share Posted June 23, 2017 Is that in the factory service manual somewhere -- "strike engine repeatedly until idle returns to normal." Well, sounds like you got somewhere, that's always good. Link to comment Share on other sites More sharing options...
VaR Posted June 24, 2017 Author Share Posted June 24, 2017 like an old tv, or vcr, just smack it a few times yeah know, and I'm pretty sure it's a remedy to one of our many tsb's:lol: Link to comment Share on other sites More sharing options...
