phitsamay.vanxay Posted June 21, 2017 Share Posted June 21, 2017 Hi all, My b4 rsk has a rod knock and would like to know where I can get a good kit to rebuild my engine with? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RustyRuu Posted June 21, 2017 Share Posted June 21, 2017 A master gasket/seal kit has all the seals and gaskets for a rebuild. Usually 330-380$$$ from the dealer. Piston rings and bearings need to be purchased separately I just bought oem rings. But I used aftermarket bearings. Kings have lasted in mine so far 15k miles. Acl bearings have been failing a lot in recent years. Stay away from those. Before you machine your heads have your master gasket kit in hand the shop will need a couple things from it or expect extra charges. Link to comment Share on other sites More sharing options...
RumbleRumble Posted June 21, 2017 Share Posted June 21, 2017 I would also tear it down first to check the crank for scoring Link to comment Share on other sites More sharing options...
phitsamay.vanxay Posted June 21, 2017 Author Share Posted June 21, 2017 I'll open up the block today Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RustyRuu Posted June 21, 2017 Share Posted June 21, 2017 Even if it's ok get it polished by the machine shop it's like 40 to 50 and they measure it. It's nothing compared to the 200$ plus for your heads. The case halves getting checked and cleaned isn't too bad either. Either way you will have metal in your oil and it's all over your engine it will need to be hot tanked if your shop has the ability to mine said there's was too hot for aluminum, so they used the alternative which was probably just oven cleaner( wash your positions with easy off non bake) . But they got it so much cleaner than I could. Have you considered a new short block or are you just looking for a hobby. The outcome in cost difference isn't much? Link to comment Share on other sites More sharing options...
phitsamay.vanxay Posted June 22, 2017 Author Share Posted June 22, 2017 Would love to get a short block. But don't know where to get one in my area. I live in Vancouver bc Canada. How much should a short block go for? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
phitsamay.vanxay Posted June 22, 2017 Author Share Posted June 22, 2017 Does anyone know a place where I can get a short block Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
phitsamay.vanxay Posted July 12, 2017 Author Share Posted July 12, 2017 Hi all, found a long block from a 2000 jdm legacy b4 rsk. Engine ej206tt rev c. Will this long block fit in my 99 jdm b4 rsk. Engine ej208tt rev a. Is it a direct swap. Please let me know asap. Going to take a look tomorrow. Thanks Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
phitsamay.vanxay Posted July 16, 2017 Author Share Posted July 16, 2017 Hi all, found a long block from a 2000 jdm legacy b4 rsk. Engine ej206tt rev c. Will this long block fit in my 99 jdm b4 rsk. Engine ej208tt rev a. Is it a direct swap. Please let me know asap. Going to take a look tomorrow. Thanks Sent from my iPhone using Tapatalk Install the new use long block and running like a dream. Perfect fit from rev A to rev B. Thanks for the help. In my case engine swap was a better route. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
