Whopper Posted June 12, 2017 Share Posted June 12, 2017 Now both heads sound like they are ticking. Im thinking timing problem. Link to comment Share on other sites More sharing options...
doublechaz Posted June 12, 2017 Share Posted June 12, 2017 You're not talking about the ticking sound the injectors make? If your oil level gets real low, or your oil pressure is low you might be getting noise from the HLAs. Link to comment Share on other sites More sharing options...
Brighton96 Posted June 12, 2017 Share Posted June 12, 2017 I second the HLAs, they are notorious for making noise. I just had to remove the one rocker assembly on one side of my motor just the other week because they were tapping really bad, and I come to find out there were two blocked oil passages. Link to comment Share on other sites More sharing options...
Whopper Posted June 12, 2017 Author Share Posted June 12, 2017 Yes it was the fact i have NO OIL. So now I need to figure out why my car had no oil. There are only 2 things it could be either the leak on my pressure sensor or the engine is burning it off. If the pressure sensor is the leak than I will be ok but if the engine is burning oil than Ill sell the car for the price of the engine (THIS). Link to comment Share on other sites More sharing options...
Setnev Posted June 12, 2017 Share Posted June 12, 2017 Yes it was the fact i have NO OIL. So now I need to figure out why my car had no oil. There are only 2 things it could be either the leak on my pressure sensor or the engine is burning it off. If the pressure sensor is the leak than I will be ok but if the engine is burning oil than Ill sell the car for the price of the engine (THIS). That is highway robbery for a bare block, unless it is a brand new 0 mileage block, which doesn't look like it. Long blocks are cheaper than that from a rebuilder. I've seen these go for $500-$1000 depending on what's included. I'd buy this before that EJ22T block. At least they're new halves. Link to comment Share on other sites More sharing options...
Whopper Posted June 12, 2017 Author Share Posted June 12, 2017 That is highway robbery for a bare block, unless it is a brand new 0 mileage block, which doesn't look like it. Long blocks are cheaper than that from a rebuilder. I've seen these go for $500-$1000 depending on what's included. I'd buy this before that EJ22T block. At least they're new halves. Yes that is expensive for just a block but for mine I know I can get at minimum 1000$ because it has a car attached to it. And yes burning oil would reduce the price. Link to comment Share on other sites More sharing options...
