spiky Posted June 9, 2017 Share Posted June 9, 2017 Hi all Just got in a accident last week, I'm ok but my 95 impreza 2 door was total. After searching I found 2005 legacy GT sedan and engine swap about 60000k with the paper proved from the shop but on body is 171000k. Here is my question in term of maintenance what the priority i need to look for. I know one thing he said timing belt not done. new break pad front and rear, new front strut. thank you for your time and thank you for every info. Link to comment Share on other sites More sharing options...
Zachariahc Posted June 9, 2017 Share Posted June 9, 2017 Are you asking what order to do those things? Link to comment Share on other sites More sharing options...
spiky Posted June 9, 2017 Author Share Posted June 9, 2017 Zachariahc: Yes, I like to know what order to do and common problem. I know this car has turbo any special care for that. thank Link to comment Share on other sites More sharing options...
Zachariahc Posted June 9, 2017 Share Posted June 9, 2017 I'd do timing belt, brakes, struts. But all of that is relevant to how bad each part is or isn't. Do you have records for the engine swap? Did the previous owner tell you why it needed a new/used engine? Was the turbo also replaced? Check this out http://legacygt.com/forums/showthread.php/turbo-failure-wiki-173358.html Lots of good information in there. Are you planning on working on this car yourself? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 9, 2017 Share Posted June 9, 2017 Timing belt kit is done every 105,000 miles. Brakes are as required. I recently put four new calipers on my 09, they are easy to replace on these cars. http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
spiky Posted June 10, 2017 Author Share Posted June 10, 2017 Thank for you all info, yes I'm planing to work on the car myself with basic stuff. and looking for thread as i needed for special job. thank again Link to comment Share on other sites More sharing options...
