dougall42 Posted April 22, 2017 Share Posted April 22, 2017 Has anyone tied aux driving lights into hi beam circuit? If so can you advise where to connect? Link to comment Share on other sites More sharing options...
fedaykin Posted April 23, 2017 Share Posted April 23, 2017 Why? You want distance lighting when using high beams, adding foreground lighting doesn't help. Link to comment Share on other sites More sharing options...
dougall42 Posted April 24, 2017 Author Share Posted April 24, 2017 I live in a rural area in Canada so want adequate warning of wildlife when I'm pressing on. Link to comment Share on other sites More sharing options...
fedaykin Posted April 26, 2017 Share Posted April 26, 2017 Retrofit bi-xenon projectors (e.g. RX350, TL, G37 sedan), problem solved Link to comment Share on other sites More sharing options...
rougeben83 Posted May 16, 2017 Share Posted May 16, 2017 To answer your question, I would have the relay switch wired in series with your high-beam switch- basically so the driving lights can only come on when your high beams are engaged. Link to comment Share on other sites More sharing options...
