starionesir Posted April 7, 2017 Share Posted April 7, 2017 Its time for a new set of tires. I have grids on the car. 18x8.5 with stock ride height. Running the slightly stretched 225 40 18 tires. Was thinking I like to go with something wider. Car currently doesn't have a issue breaking those tires loose. I do have a set of coilovers that are going to be installed shortly so I don't want to run into a issue with rubbing. Wanted to go 245 35 18 but wanted to see if anyone out there had any rubbing issues with that size. Link to comment Share on other sites More sharing options...
whitetiger Posted April 7, 2017 Share Posted April 7, 2017 245/35/18 is the correct size. depending on tire selection, you may need a fender roll. or more camber. this is all assuming the wheels are +48 offset. Link to comment Share on other sites More sharing options...
rapture Posted April 7, 2017 Share Posted April 7, 2017 I run 235 40 18 Was also wondering if i can push it to a 45 or 245 or both Im on bilstien hd's cobb springs, spec b cntrl arms Gt spec tie rod kit Largest sways, w perrin /cart-boy endlinks .... On some 18x8.5 xxr's Link to comment Share on other sites More sharing options...
starionesir Posted April 7, 2017 Author Share Posted April 7, 2017 Looked up my grids on wheeldudes website. Place I bought them from. Looks like the offset is 44mm. Link to comment Share on other sites More sharing options...
whitetiger Posted April 7, 2017 Share Posted April 7, 2017 ok, so 245/35/18 should be ok. be prepared to do a roll or dial in more camber. I assume your coilovers have camber plates. if not, get some and a rear camber adjustment solution as well. Link to comment Share on other sites More sharing options...
starionesir Posted April 7, 2017 Author Share Posted April 7, 2017 Any issue with running that tire a stock height until I can get something to adjust camber in the rear? Link to comment Share on other sites More sharing options...
whitetiger Posted April 7, 2017 Share Posted April 7, 2017 no, it will just look a little funny. id still roll the rear, regardless. that lip back there is huge. Link to comment Share on other sites More sharing options...
starionesir Posted April 7, 2017 Author Share Posted April 7, 2017 Look funny? I'm assuming because of the amount of tire sticking out? I have a friend that is repainting the rear bumper and he is going to roll my fenders while he has the car. Link to comment Share on other sites More sharing options...
whitetiger Posted April 7, 2017 Share Posted April 7, 2017 Look funny? I'm assuming because of the amount of tire sticking out? I have a friend that is repainting the rear bumper and he is going to roll my fenders while he has the car. yeah, that and the wheel gap due to stock ride height. Link to comment Share on other sites More sharing options...
TonyF Posted April 18, 2017 Share Posted April 18, 2017 I would like to see pics of 245 35 18 48mm installed with 8" wheels on the car; My 06 LGT is lowered only slightly due to springs and about -2 camber (max on stock bolts) and wanted to go from 225 45 17 48mm x7" to something with more grip like the wrx guys, very scared about wasting money on something that might rub Link to comment Share on other sites More sharing options...
whitetiger Posted April 18, 2017 Share Posted April 18, 2017 will be fine on a 18x8.5 +48 wheel, but you will need to roll fenders some. i ran this exact setup in this vid. Link to comment Share on other sites More sharing options...
TonyF Posted April 18, 2017 Share Posted April 18, 2017 nice, looking fast. much appreciate the sharing I'm running STX, no real power mods, felt like I need more rubber because the re71r's break loose a little too easy at 225 width. Would you say having that extra 20mm of grip makes a noticeable difference? https://www.youtube.com/watch?v=sZoVOMmpnec Link to comment Share on other sites More sharing options...
whitetiger Posted April 18, 2017 Share Posted April 18, 2017 20mm helps, aligment is important too, but i was running r-comps so that helps most Link to comment Share on other sites More sharing options...
whitetiger Posted April 18, 2017 Share Posted April 18, 2017 nice, looking fast. much appreciate the sharing I'm running STX, no real power mods, felt like I need more rubber because the re71r's break loose a little too easy at 225 width. Would you say having that extra 20mm of grip makes a noticeable difference? https://www.youtube.com/watch?v=sZoVOMmpnec you need to work on your hand position. you shuffle the wheel too much. keep your hands at 9 and 3, and only hand over hand once when you have to. Link to comment Share on other sites More sharing options...
TonyF Posted April 18, 2017 Share Posted April 18, 2017 agree 100% still a noob, but I am working on it also doing some hpde so I am working on various things, had some cooling issues recently but I'll know next month if my fixes helped or if I need to do motor work recently worked on springs and best possible alignment on near stock setup, tires are lasting longer so I'm in a happy place, for now... Link to comment Share on other sites More sharing options...
