Blue Posted March 31, 2017 Share Posted March 31, 2017 I'm looking for wheels for a car project, and due to odd dimensions, the wheels are going to have to be at least partly custom. Offset and bolt pattern are both non-standard. The Tire Rack doesn't have a single wheel with the required bolt pattern. Suggestions for custom wheel manufacturers.....? Thank you! Link to comment Share on other sites More sharing options...
whitetiger Posted March 31, 2017 Share Posted March 31, 2017 what dimensions are you looking for? ther are plenty of custom wheel makers out there who make custom machined forged wheels. Fikse Forgeline CCW are some names that come to mind, but i am not vouching for them as business. some vendors like Ravspec have contacts to bring in JDM spec wheels depending on what your project is. None of this will be cheap though. Link to comment Share on other sites More sharing options...
Blue Posted March 31, 2017 Author Share Posted March 31, 2017 A 16 or 17 inch diameter wheel. Fronts 7 in wide with a +23 mm offset. Rears 8 inches wide with a -20 mm offset. Bolt circle 5 x 120.65 mm. Thank you for the suggestions. I'll check them out. Link to comment Share on other sites More sharing options...
boxkita Posted March 31, 2017 Share Posted March 31, 2017 Swap hubs or buy wheels without the bolt circle drilled. Enkei has that option on their racing line. Summit has these - https://www.summitracing.com/search/part-type/wheels/wheel-diameter/17-in/wheel-bolt-pattern/5-x-120-65mm/manufacturers-wheel-series/american-racing-torq-thrust-ii-series So you could call American racing and ask them about custom specs. Expect to pay alot for 1-off wheels. For reference, I was looking for custom sized wheels for my LGT wagon. Enkei wanted 40 wheels (all same spec) for a color change. For a spacing change, I had to buy 100 wheels. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Blue Posted March 31, 2017 Author Share Posted March 31, 2017 Yeah, I'm hoping to find a company that works with "blanks" - where the offset and bolt pattern can be machined to the specs I need. And that don't cost a fortune! Link to comment Share on other sites More sharing options...
boxkita Posted March 31, 2017 Share Posted March 31, 2017 Expect $2000 per wheel for something custom. Id call American Racing and ask for the custom department. See what they can do. Or call one of the SoCal custom rod builders. Ask them to make you a set of wheels. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
quick4dr Posted April 27, 2017 Share Posted April 27, 2017 INCURVE WHEELS, danny_incurve on instagram, tell him I sent you. Link to comment Share on other sites More sharing options...
