landcrush Posted March 20, 2017 Share Posted March 20, 2017 Was hoping somebody could look at my logs for ECUFlash and see if they can pinpoint where I'm going wrong. To start, the engine is currently out of the car ie; the harness isn't hooked up so that very well could be my issue. I'm only trying to read/save the current ROM on my car in preparation for an e-tune. [16:52:33.960] Logging to file C:/Users/evanc/AppData/Roaming/OpenECU/EcuFlash/logs/ecuflash_log_20170319t165233.txt [16:52:33.960] EcuFlash Version 1.44.4799 [16:52:33.960] OS Version Windows 10 [16:52:33.960] Kernel Type winnt [16:52:33.960] Kernel Version 10.0.14393 [16:52:33.960] CPU x86_64 [16:52:33.960] Product Name Windows 10 [16:52:33.960] Product Type windows [16:52:33.960] Product Version 10 [16:52:33.960] Qt Version 5.6.0 [16:52:33.960] Qwt Version 6.1.2 [16:52:33.960] QwtPlot3D Version 0.2.6 [16:52:33.960] Boost Version 1.60 [16:52:33.960] FTDI Library Version 3.02.11 [16:52:33.960] Openport J2534 Library Version 1.02.4798 [16:52:33.976] 67 memory models read. [16:52:33.976] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata [16:52:34.146] 745 ROM metadata models scanned. [16:52:34.146] checksum module "subarudbw" loaded. [16:52:34.146] checksum module "subarudiesel" loaded. [16:52:34.146] checksum module "subaruhitachi" loaded. [16:52:34.146] checksum module "mitsucan" loaded. [16:52:34.146] checksum module "mitsuh8" loaded. [16:52:34.146] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded. [16:52:34.146] patch module "Mitsu CAN RAM Parameter Logging" loaded. [16:52:34.151] using metadata XML ID read_subarush7058can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_subarush7058can.xml [16:52:34.157] flashing tool "wrx02" loaded. [16:52:34.159] flashing tool "wrx04" loaded. [16:52:34.161] flashing tool "sti04" loaded. [16:52:34.163] flashing tool "sti05" loaded. [16:52:34.167] flashing tool "mitsucan" loaded. [16:52:34.167] flashing tool "mitsukernel" loaded. [16:52:34.167] flashing tool "mitsukernelocp" loaded. [16:52:34.167] flashing tool "mitsubootloader" loaded. [16:52:34.167] flashing tool "shbootmode" loaded. [16:52:34.167] flashing tool "shaudmode" loaded. [16:52:34.170] flashing tool "subarucan" loaded. [16:52:34.173] flashing tool "subarucand" loaded. [16:52:34.176] flashing tool "subarubrz" loaded. [16:52:34.179] flashing tool "subaruhitachi" loaded. [16:52:34.198] J2534 API Version: 04.04 [16:52:34.198] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10 [16:52:34.198] Device Firmware Version: 1.16.4769 [16:52:34.198] Device Serial Number: TAGFRngW [16:52:34.199] interface close (then got this that included J2534 ERR) [16:52:39.997] using metadata XML ID read_subarush7058can from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_subarush7058can.xml [16:52:40.013] J2534 API Version: 04.04 [16:52:40.013] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10 [16:52:40.013] Device Firmware Version: 1.16.4769 [16:52:40.013] Device Serial Number: TAGFRngW [16:52:42.639] kernel get version [16:52:42.838] J2534 error [ERR_TIMEOUT]. [16:52:43.055] J2534 error [ERR_TIMEOUT]. [16:52:44.509] interface close [16:52:44.509] interface close Link to comment Share on other sites More sharing options...
