Mikica Posted March 12, 2017 Share Posted March 12, 2017 Im an proud owner of subaru legacy 1991 LS. Yesterday i changed my timing belt on my car and when i turned on my engine it was running smoothly but i noticed there was no square light on dashboard to indicate which gear level am i using. When i test drive it, its on a drive mode, when i attempt to moved this on 3rd gear,and 2nd gear, it doesnt change at all. Even in manual mode. Only what i can assume the problem came from when i screw up the bolt on balancer i tried to wedge using the screw driver on the crankshaft (to tighten the bolt)from behind the engine. Can any one figure out the problem with my Subaru? Thanks! Link to comment Share on other sites More sharing options...
