Infosecdad Posted March 6, 2017 Share Posted March 6, 2017 I have P-204UH w/ Sirius Sat Radio hooked up. I'm trying to figure out if the Grom BT3 (SUB08B3), which connects to the satellite plug, can be put inline and still allow access to the sat radio. Anyone have both working? If so, how do you switch between them? Link to comment Share on other sites More sharing options...
utc_pyro Posted March 6, 2017 Share Posted March 6, 2017 The data bus can support multiple devices, things like the GROM and iSimple stuff spoof that they are multiple devices to change inputs. The harness supports pass through as well. So in theory yes, but you'll have to check to be sure. Link to comment Share on other sites More sharing options...
Infosecdad Posted March 10, 2017 Author Share Posted March 10, 2017 I installed the GROM BT-3 today. Even though it plugs into the satellite plug (daisy chain), it is accessible from the AUX control on the front. Awesome setup. I now have the Nexus 7 USB DAC plugged into 3.5mm, USB power for the iPhone, Bluetooth controls for iPhone and can even control music from the buttons on the stock P-204UH stereo. Very happy with the setup, sound is clean and crisp. Link to comment Share on other sites More sharing options...
amp583 Posted November 20, 2017 Share Posted November 20, 2017 I bought the GROM IPD4 for my 08 LGT Sat NAV and believe I connected it in the right way. Basically I pulled out my iSimple Audio gateway and reconnected to the same dins. My playback keeps cutting out when set to Sat 1. It'll play 1-2 seconds, cut out and play another 1-2 and eventually switch from Sat 1 to Sat 01. Perhaps I connected it incorrectly? Link to comment Share on other sites More sharing options...
Infosecdad Posted November 20, 2017 Author Share Posted November 20, 2017 Did you order it with Sat emulation or CD Changer (CDC) emulation? I ordered mine with CD Changer emulation and while it's inline with the sat, it's accessible via Aux. Link to comment Share on other sites More sharing options...
DadBod Posted May 9, 2018 Share Posted May 9, 2018 I have the same unit in my 08 OBXT. Have you tried flashing the unit to the latest firmware? That did the trick for me. Firmware is found here: https://gromaudio.com/software-ipd3.html Just make sure you select the correct options. If that doesn’t work, try their online help. They were quick to reply when I had some questions about which set up to order from them. Link to comment Share on other sites More sharing options...
