Energyblue98 Posted July 31, 2017 Author Share Posted July 31, 2017 Dude. I wanted those wheels so bad lol. The closest style i can find to them are the Focal F04 wheels. Which is what ill end up getting to replace the xxr's. Looking forward to this build though! I'm debating selling the wheels, I still have the advan RS's from my spec.B so I might use those instead.. Link to comment Share on other sites More sharing options...
Dishwasher Posted October 17, 2017 Share Posted October 17, 2017 subbed. Brought to you by Pfizer Link to comment Share on other sites More sharing options...
JohnnyWas Posted October 22, 2017 Share Posted October 22, 2017 Your SpecB was very cool, but evermore excited to see another purist / proponent of good-taste in a wagon!! SUBBED! Link to comment Share on other sites More sharing options...
Energyblue98 Posted November 29, 2017 Author Share Posted November 29, 2017 Just a quick update.. found out from the previous owner to the previous owner that the body of the car had some water damage from the windows being left down. upon tearing into the wiring underneath the dashboard, it appears that the previous owner might have changed out the dash board with all new wires, but the BIU is still the original and appears to have some water damage, which would explain why it's not reading. Waiting on a new BIU and matching ECU and we'll see if that works! Link to comment Share on other sites More sharing options...
BL5BO Posted November 29, 2017 Share Posted November 29, 2017 Thanks for the update!!! Looking forward to moving forward! My "Alpine White" 06 LGT: The Kabigon [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
cSlenker802 Posted November 29, 2017 Share Posted November 29, 2017 I'm late to the party but I just wanna say I loved your youtube channel even before I knew you had a spec b! I was stoked when I saw that you bought the wagon and can't wait to see what you do with it. Sub'd. Link to comment Share on other sites More sharing options...
theflystyle Posted November 30, 2017 Share Posted November 30, 2017 +1 Sub'd your YouTube channel as soon as I found out you were messing with the Legacy and were in the DMV area. Best of luck! Link to comment Share on other sites More sharing options...
Energyblue98 Posted December 1, 2017 Author Share Posted December 1, 2017 +1 Sub'd your YouTube channel as soon as I found out you were messing with the Legacy and were in the DMV area. Best of luck! Thanks man! Link to comment Share on other sites More sharing options...
kzr750r1 Posted December 2, 2017 Share Posted December 2, 2017 Subbed here and at the you tubes... good luck! Link to comment Share on other sites More sharing options...
BDII Posted December 2, 2017 Share Posted December 2, 2017 I need to keep watching these. Great job on the channel! Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Energyblue98 Posted December 3, 2017 Author Share Posted December 3, 2017 The car runs!!! I haven't told anybody yet, so you guys are the first to know It turned out to be a couple missing grounds and the fuel pump relay was corroded. so I swapped that out and it fired for the first time! It's a 100% Brand new motor so I'm a bit nervous about treating it right. I might sure it had oil cycled through with just the starter motor first. However, it's not all sunshine and rainbows. Its making a bad grinding noise while running. So I haven't left it on for more than a few seconds. I replaced the starter with a different starter that I had but the noise is still there. It sounds like it's coming from the back of the engine. My next thing to check is to see if the transmission has fluid in it :/ wupps. It's a 6 speed swap with what appears to be an 08 STI. No dipstick. Does anybody have a good easy way to check to see if it has fluid it in without unbolting the drain plug? Link to comment Share on other sites More sharing options...
BDII Posted December 3, 2017 Share Posted December 3, 2017 Spoliers! Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted December 3, 2017 Share Posted December 3, 2017 congrats on the progress! Link to comment Share on other sites More sharing options...
skier LGT Posted December 3, 2017 Share Posted December 3, 2017 Glad to hear that it's at least running now! Hope you can find the problem without too much work. Love your channel man, keep it up. Link to comment Share on other sites More sharing options...
RustyRuu Posted December 4, 2017 Share Posted December 4, 2017 maybe someone would be so kind here to measure there 6mt dipstick and you could use a coat hanger or old wire cut to length. can't wait to see the next video Link to comment Share on other sites More sharing options...
sshole Posted December 4, 2017 Share Posted December 4, 2017 Unbolt the fill plug on the side of the transmission. If you can stick your finger in the fill plug and feel fluid, I'd imagine that it has enough fluid. Link to comment Share on other sites More sharing options...
Energyblue98 Posted December 14, 2017 Author Share Posted December 14, 2017 Confirmed. The car still has transmission fluid. I'm not sure what the sound could be.. Link to comment Share on other sites More sharing options...
sshole Posted December 14, 2017 Share Posted December 14, 2017 You sure the clutch assembly is in good shape? Link to comment Share on other sites More sharing options...
Energyblue98 Posted December 15, 2017 Author Share Posted December 15, 2017 You sure the clutch assembly is in good shape? I'm not. From what I can see through the bottom by bending that little plate back it looks like the pressure plate is all fine but flywheel bolts could be loose. Also something I'm semi concerned about that you guys might be able to clarify. Could a WRX clutch and flywheel fit on that assembly? (it's a JDM 08 sti 6 speed trans), and if it could fit on there then maybe that's my issue? maybe there's a wrx clutch and flywheel in there? Link to comment Share on other sites More sharing options...
912 Posted January 2, 2018 Share Posted January 2, 2018 Love your channel - the quality level is excellent and you and your channel-partner seem to be down-to-earth and entertaining Link to comment Share on other sites More sharing options...
Gex Posted January 12, 2018 Share Posted January 12, 2018 Just watched part 3 of your build on your channel. Looks like you bought quite the headache! Hoping it turns out for the best. I would be in the same boat as you trying to chase those electrical gremlins! Link to comment Share on other sites More sharing options...
stocklgt Posted January 16, 2018 Share Posted January 16, 2018 RE: Clutch - this may help https://forums.nasioc.com/forums/showthread.php?t=1772793 I believe the 02-05 WRX clutch can be used with the JDM STi trans, but depending on the year of the trans you may not be able to use it. Food for thought. With what you've been through so far, maybe a new clutch setup would just be the smarter move. I would go with the proper clutch setup and move on from there, it just seems to make sense since so much of this car has been a lesson in frustration. Good luck as always, love the youtube channel! Link to comment Share on other sites More sharing options...
BDII Posted January 16, 2018 Share Posted January 16, 2018 When's part 4 coming out? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
plboard Posted February 1, 2018 Share Posted February 1, 2018 Following this on youtube, love the content man! Link to comment Share on other sites More sharing options...
BDII Posted February 1, 2018 Share Posted February 1, 2018 When's part 4 coming out? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
