dvnner Posted January 22, 2017 Share Posted January 22, 2017 Hey forum, Bought myself a 93 Legacy from the thrift store this weekend for the total price of 295$ I've checked my fluids and such and have put about 100 miles on it so far and it seems to be ok for a 300$ AWD car. Why so cheap? The trans slips in full on auto mode. So what I was doing to help prevent most of the slipping was put it in to 'manual' mode and shift when needed. This has been doing fine for the last 2 days until today. Everytime i put it in manual mode and shift down past D it kills the car. I can put it in auto mode and go down to to 1st and it runs decently. What can I do here? Also my VW had some trans slipping issues and a simple trans flush helped a ton. Would this be similar for a Subaru? Link to comment Share on other sites More sharing options...
SuperSub Posted January 22, 2017 Share Posted January 22, 2017 I would just get a new auto box. Would expect them to be pretty cheap and if you can install yourself as well then it saves money too. Should be able to pick a second hand box for a few hundred and will still make it a cheap car. Link to comment Share on other sites More sharing options...
wtdash Posted January 23, 2017 Share Posted January 23, 2017 Also my VW had some trans slipping issues and a simple trans flush helped a ton. Would this be similar for a Subaru? Does the POWER light flash 16 times @ startup? If so, there's a CODE stored in the transmission, which will tell you WHAT the issue is...or @ least a clue. CODEs HERE. I wouldn't do a chemical or power flush, just Drain, Refill, Drive (10 miles), and repeat 3 Times to replace 90% of the ATF. If you're (very) lucky it might help. I wouldn't spend any $ on the Trans "remedies" if the ATF replacement doesn't help. The '92-'94 Legacy Automatic AWD (4EAT) are your avl. years to swap in as they had the 3.90 FD Ratio. Anything else from '90-'91 or '95-'98 will require a REAR DIFF swap too (4.11). Also, the '91-'94 Legacy TURBO (SS and TW) trans was the same as your '93....but much harder to find. Link to comment Share on other sites More sharing options...
