PurpleSNow Posted January 16, 2017 Share Posted January 16, 2017 I found a few plughs with no mates under that dash when i was sorting out alarm problem. I found 2 green plugs male and female but diff colour wires. damit now I cant remember the colors. will check then quick tomorrow. and also just make not of the other plugs. everything works on the car im just curious what they might be for. and the wiring diagram i have doesnt really help finding them Link to comment Share on other sites More sharing options...
Osei Posted January 18, 2017 Share Posted January 18, 2017 They are test connectors. Leave them unplugged. When joined and the ignition in the start position, all your relays will cycle (click) and both fans will run. O. Link to comment Share on other sites More sharing options...
PurpleSNow Posted January 19, 2017 Author Share Posted January 19, 2017 ah ok thank you. im very new to subaru as this is my first one lol always been driving VW Link to comment Share on other sites More sharing options...
wtdash Posted January 23, 2017 Share Posted January 23, 2017 Legacy Diagnostic / Test Connectors Green (active) and Black (stored / historical ) Link to comment Share on other sites More sharing options...
PurpleSNow Posted February 14, 2018 Author Share Posted February 14, 2018 I only noticed now. will it hurt anything or affect the car if the black plugs were connected all the time. Like I said im new. there were globes missing in the cluster and replaced them now everyting is lit incl the abs and eng light. I found some fault codes t last but the abs light is the one worrying me. it comes on after a minute or two and stays on. Link to comment Share on other sites More sharing options...
wtdash Posted February 14, 2018 Share Posted February 14, 2018 " I found some fault codes " And what were they??? The ABS light is likely the sensor @ one wheel needs cleaned off or replaced. Whatarethecodes??? Link to comment Share on other sites More sharing options...
PurpleSNow Posted February 14, 2018 Author Share Posted February 14, 2018 35 Canister purge selenoid 49 Airflow sensor Link to comment Share on other sites More sharing options...
Omega79 Posted February 18, 2018 Share Posted February 18, 2018 If the black ones are connected all the time it will show stored codes. Even if the codes are no longer valid, if the ECU hasn't been properly reset they'll still show. It won't "hurt" anything but your check engine light will always be on and it may just be my mind playing tricks on me, but every Legacy I've accidentally left them plugged in on seemed to run worse with them connected. Link to comment Share on other sites More sharing options...
PurpleSNow Posted February 22, 2018 Author Share Posted February 22, 2018 and i just wanted to make sure on clearing the faults. do u bridge out the white plug Link to comment Share on other sites More sharing options...
