ephemeric Posted January 3, 2017 Share Posted January 3, 2017 Hi, My mechanic did the below. Tapped the oil drain plug to fit oil temperature or pressure sensor. Is it just me or is this simply awful? Link to comment Share on other sites More sharing options...
bigleben Posted January 3, 2017 Share Posted January 3, 2017 Hope for you its the oil temperature otherwise its pretty useless... Link to comment Share on other sites More sharing options...
MTBwrench Posted January 3, 2017 Share Posted January 3, 2017 Wow... that's pretty horrific, I will admit. The best part about the situation is that it's easily reversible, just buy a new drain plug and you're all fixed up. My guess is that, assuming this is a temp sensor, the mechanic was too lazy to pull the pan, so he decided to do the next best lazy option; tap the plug and cal it a day. MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted January 3, 2017 Share Posted January 3, 2017 Pretty pointless I would've thought. Link to comment Share on other sites More sharing options...
tocinoman25 Posted January 3, 2017 Share Posted January 3, 2017 Is it me or does the photo look chopped? Sent from my SM-G935V using Tapatalk Follow me on IG @chefodiycarguy and @chefo.soriano Link to comment Share on other sites More sharing options...
ehsnils Posted January 3, 2017 Share Posted January 3, 2017 Well, it's not the worst thing to do to get the oil temp. And if you find that you want to reverse it you can get a magnetic oil plug instead. I just hope that the connector and wiring is oil resistant as well as sealed from water or this will only work for a limited time. Link to comment Share on other sites More sharing options...
ephemeric Posted January 4, 2017 Author Share Posted January 4, 2017 Hope for you its the oil temperature otherwise its pretty useless... It is temperature, I have checked and confirmed with my colleague who is very knowledgeable. Link to comment Share on other sites More sharing options...
madrig Posted February 4, 2017 Share Posted February 4, 2017 is not pretty , but i think is the best place to get the temperature . Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted February 4, 2017 I Donated Too Share Posted February 4, 2017 is not pretty , but i think is the best place to get the temperature . Is it? I think that's debatable to call it 'the best'. Bottom of the oil pan means there is hotter oil above it but what that difference is I am not sure. Most simple place to take a relevant temp is near the oil filter on a sandwich plate. Accuracy of the actual temp is less important than knowing what's normal and being able to detect a sudden change. Link to comment Share on other sites More sharing options...
ehsnils Posted February 4, 2017 Share Posted February 4, 2017 Considering that the oil is circulating a lot through the engine the top and bottom won't make any difference. It's not unusual to measure it on the drain plug on aftermarket installations, but OEM installations usually have a dedicated sensor in the oil tray. Link to comment Share on other sites More sharing options...
madrig Posted February 4, 2017 Share Posted February 4, 2017 Is it? I think that's debatable to call it 'the best'. Bottom of the oil pan means there is hotter oil above it but what that difference is I am not sure. Most simple place to take a relevant temp is near the oil filter on a sandwich plate. Accuracy of the actual temp is less important than knowing what's normal and being able to detect a sudden change. i agree with you , a sandwich plate is a very good spot , like you say accuracy of the actual temp is less important than knowing what's normal and being able to detect a sudden change. Link to comment Share on other sites More sharing options...
