Joaks Posted December 31, 2016 Share Posted December 31, 2016 Dear all, I am thinking to make my mirrors heated. I have two options (that I know of): #1 install OEM style heated mirrors or #2 install a heater to my current mirrors. I dug through the archives and it looks like to do the OEM method I would need to get the wiring harness which I expect to be a pain. This is unless the wire for the heater is separete and I could hook the heated mirrors just as my non-heated and add a separate wire and switch. I don't think I can do this however so was thinking to go with option #2, which would also be much cheaper. Has anyone done this? It looks very straightforward, aside from getting the glass off. Any thoughts? Link to comment Share on other sites More sharing options...
Brighton96 Posted December 31, 2016 Share Posted December 31, 2016 I currently have heated mirrors in my car too but I haven't bothered to wire them up. The plug for the heater is only 2 prong and the power mirror is 4? I think. So it would be pretty easy to wire them up with a switch or you could just tap into the power for the power mirror if your car has that option. To wire them up, the way I would do it is put a fuse tap in the fuse box and just run 2 wires into each of the doors and then find a way to connect the new wires to the stock connector so I will be able to disconnect it easier in the future. Link to comment Share on other sites More sharing options...
