Teewadd Posted December 26, 2016 Share Posted December 26, 2016 Recently installed my Q300 CBE, mated to stock DP for now. (Have invidia catless DP...but also have 3 siezed nuts on my turbo to DP flange). Anyways, there seems to be some common minor fitment issues with this system but mine is a bit excessive. The mid pipe to muffler section is hanging maybe 2" off the ground, and there's no way to make it high enough to reach the exhaust hanger. Famous last words, but I'm 99.99% sure it's installed correctly, as it is shaped the same way the stock exhaust was. Any advice? Link to comment Share on other sites More sharing options...
Rhitter Posted December 26, 2016 Share Posted December 26, 2016 I am confused by "there is no way to make it higher to reach the exhaust hanger". Did you try bolting the midpip up, then hanging it off the exhaust hanger by the rear diff, then connecting the muffler? There should be a way to get the mid-pipe up higher. My OBXT build Link to comment Share on other sites More sharing options...
Teewadd Posted December 27, 2016 Author Share Posted December 27, 2016 I will try that, I put the Whole exhaust together then attempted to hang it all up as an entire unit, I'll attack it piece by piece and see how that goes, thank you. Link to comment Share on other sites More sharing options...
SpecBlitzed Posted December 27, 2016 Share Posted December 27, 2016 Damn I got the same one and mine sits low but not that low. How much distance is there from the exhaust hanger. Link to comment Share on other sites More sharing options...
