computersoc Posted December 31, 2016 Author Share Posted December 31, 2016 If a fuse blew, wouldn't it not work at all? Link to comment Share on other sites More sharing options...
brandon.mol Posted January 1, 2017 Share Posted January 1, 2017 Correct. In other words, the 12v lighter socket is not "limiting" the current. Its either low system voltage, or the adaptor you are using isn't making good contact and is only intermittently charging your device or the adaptor is reducing the output for some reason. I suggest you buy a cheap USB current tester as pointed out above as well as an inline mini fuse current tester, and you can observe the 12v side current and the 5v side current. Might want to test whether the USB is actually running at 5v or 9v too. Link to comment Share on other sites More sharing options...
