Jmack76 Posted December 24, 2016 Share Posted December 24, 2016 So something went in my transmission today. When you put the car in any gear it will start to move and then nothing at all a second later. Then shut it off and it will do that allover again, it just started doing this today but I noticed a whine from it yesterday. The car is a jdm 1999 legacy gt wagon Link to comment Share on other sites More sharing options...
RumbleRumble Posted December 24, 2016 Share Posted December 24, 2016 Sounds like a differential bearing problem hard to tell. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 24, 2016 Share Posted December 24, 2016 check your front 2 half shafts and make sure one is not BUSTED Link to comment Share on other sites More sharing options...
Jmack76 Posted December 24, 2016 Author Share Posted December 24, 2016 Thanks I will check out and see if it is either of those things. I am new to Subarus so don't know much about them yet Link to comment Share on other sites More sharing options...
OLsubedrvr Posted December 26, 2016 Share Posted December 26, 2016 Check all related fluids. Link to comment Share on other sites More sharing options...
Jmack76 Posted December 27, 2016 Author Share Posted December 27, 2016 I have checked all the fluids they are good. I was thinking maybe it was contamination in the fluids or something. Link to comment Share on other sites More sharing options...
OLsubedrvr Posted January 2, 2017 Share Posted January 2, 2017 I have checked all the fluids they are good. I was thinking maybe it was contamination in the fluids or something. Could be, or maybe an old/dirty filter too. I have a 99 Legacy w/auto trans and those are prone to a shifting issue when cold. Mine has had a recent,(1yr ago), flush & refill and still bogs, (won't upshift until warm). Otherwise it shifts smooth, keep searching and good luck Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 7, 2017 Share Posted January 7, 2017 I have found that using Valvoline synthetic fluid works really well for fixing the 2-3 accumulator charge delay on first shift when cold. As soon as I put that stuff in my 2003 Legacy the transmission immediately ceased to have that problem and also quit with the occasional harsh downshift from 4-3 when slowing down. car now has 108K on it. Also I would STRONGLY recommend changing that external filter as well... after 18+ years, it's done. also the TCM will delay upshifts to aide in warming the engine up so when it is cold delayed upshifts is very normal. Link to comment Share on other sites More sharing options...
