BagRidersJohn Posted December 20, 2016 Share Posted December 20, 2016 Hey LGT friends, I've got a 2007 specB with about 170k on it and I've been planning on rebuilding the engine as it's probably about time and it's something I enjoy doing. I found a local 2005 LGT that according to the owner, has low compression on one cylinder. I went and checked it out last night and it's in excellent condition, started right up, and ran just fine. He wanted $2500 but I talked him down to $2000. I have the knowledge, tools and skill set to rebuild the engine which is why I'm considering this route. Question: My understanding is that the specB and LGT have the same longblock throughout 05-09, is this true? Are they direct swap motors? My plan is to pick up the LGT, yank the motor, rebuild it over the winter (slowly and stress free!), then swap it into my specB whenever I'm done. After break-in and determining all is well, the specB's old motor will get some love and be plopped into the LGT which I'll then sell that to cover whatever costs I've incurred, and hopefully make a couple bucks Thanks for any input! My 2007 specB (full undercarriage & drivetrain refinish, every nut and bolt replaced, full engine rebuild/restore, glass-out respray, air ride, wide body, and more! All done by me, at home!) Instagram: @bagriders_john for more Subarus (and also my wife and cat) Link to comment Share on other sites More sharing options...
boxkita Posted December 20, 2016 Share Posted December 20, 2016 Why not start a new shortblock? This seems like the harder approach. rebuild the o5 and sell it. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
BagRidersJohn Posted December 20, 2016 Author Share Posted December 20, 2016 Why not start a new shortblock? This seems like the harder approach. rebuild the o5 and sell it. I appreciate the input and consideration, but really just looking for an an answer to my question If I bought a new or used shortblock or longblock to swap into my specB, I'd be left with an engine or parts of an engine to sell once I'm done. In my experience, it's much easier to sell engines when they're attached to a working vehicle Is this approach harder and requires more work on my behalf? Definitely. That's something I'm perfectly OK with. I'm not strapped for cash and I enjoy the labor. My 2007 specB (full undercarriage & drivetrain refinish, every nut and bolt replaced, full engine rebuild/restore, glass-out respray, air ride, wide body, and more! All done by me, at home!) Instagram: @bagriders_john for more Subarus (and also my wife and cat) Link to comment Share on other sites More sharing options...
boxkita Posted December 20, 2016 Share Posted December 20, 2016 Sb are all the same. Heads are different. Ecu are different. as usual, all of this is easily searchable on this site. Look in motor rebuild section for gotchas. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Dishwasher Posted December 20, 2016 Share Posted December 20, 2016 Spec B motor and LGT motor are virtually identical. Heads are slightly different as well as piston shape, however they are indeed interchangeable. EJ255 = (2005 LGT), EJ257 = (07 SpecB) Link to comment Share on other sites More sharing options...
BagRidersJohn Posted December 21, 2016 Author Share Posted December 21, 2016 Totally forgot about the air injection pump on the 07+ that results in the difference in cylinder heads and electrical stuff-- doh! My 2007 specB (full undercarriage & drivetrain refinish, every nut and bolt replaced, full engine rebuild/restore, glass-out respray, air ride, wide body, and more! All done by me, at home!) Instagram: @bagriders_john for more Subarus (and also my wife and cat) Link to comment Share on other sites More sharing options...
