Anyone know of a Safety/kill switch, due to changing a rear shock and then the car do
Had the rear jacked up with front tires on ground, for enough room to work on spring and shock, 5 hrs later next morning car just cranks and cranks, will give a putter like little combustion happens but thats like once every 15 cranks, getting pressurized fuel, and compression, just now no spark over changing a shock wtf!?!?![emoji16]
Sent from my SM-G900V using Tapatalk
Didn't touch anything else, car ran just fine before changing shock no staying issues what so ever, what had been in my head is maybe I turned the rear wheel and threw off the timing, but now knowing the fuel model is located were I was, will have to check that out now, much appreciated guys will let know, or if have any other ideas please feel free
funnily enough we had this happen on one of my friends cars. jacked it up to swap out the struts, and then it wouldn't start after we were done. problem ended up being timing, it had jumped a few teeth. seems like it would be more coincidence than anything though.
That probably has to be my issue as well! Never messed with adjustment on timing, is there a video link or site I can see how its done, and was it pretty easy??
there are some good guides for timing belts that a google search will lead you to. it's pretty easy to do.
like I said, I think our issue was pure coincidence. it's very possible that your issue is something completely different.
