smoser703 Posted December 18, 2016 Share Posted December 18, 2016 I have a 2005 Legacy GT and recently have noticed a strong smell of what I think is oil. The only residue that I noticed was on the bottom passenger side of the turbo cooler. Has anyone had a similar issue that could give me advice. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted December 18, 2016 Share Posted December 18, 2016 Passenger side valve cover gasket is common for this, start there. Link to comment Share on other sites More sharing options...
MAP Posted December 18, 2016 Share Posted December 18, 2016 Any of the following could cause burning oil smell once they come in contact with the exhaust: Leaking valve cover gaskets Leaking oil cooler seal Torn cv joint boot And my nemesis leaking power steering pump This is the single most annoying thing about this car in the almost 8 years I've owned it. I have had no more than a few months of no oil burning smell due to the items mentioned above. I'm on my third power steering pump. The rebuilds that i've bought only last a few months with no leaks. Once they leak the oil runs down the engine making a mess and burning as it hits the exhaust. Link to comment Share on other sites More sharing options...
rizzors25 Posted December 18, 2016 Share Posted December 18, 2016 Same here. My car has a small leak somewhere but has fresh valve cover gaskets haven't found it. No smoke or anything but this happens pretty frequently to me as well Link to comment Share on other sites More sharing options...
spacemanspif Posted December 19, 2016 Share Posted December 19, 2016 Does this smell tend to come in through the heater ducts? Mrs. Spif has been getting a burn like smell through the heater and mostly only while stopped. Due to the nature of it, I'm guessing a small oil leak that burns and gets blown out the engine bay while driving but collects under the hood while stopped and is thus drawn in through the blower fan. Link to comment Share on other sites More sharing options...
MAP Posted December 19, 2016 Share Posted December 19, 2016 Yes that is the problem. The a/c / heater has to be constantly in recirculate mode otherwise you get the nasty smell blown into the passenger cabin at every stop. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted December 19, 2016 Share Posted December 19, 2016 I've found if the oil filter isn't nice and tight it'll slowly drip onto the exhaust manifold or heat shields. Most noticeable after a coming to a stop after a high speed run. Link to comment Share on other sites More sharing options...
Volta55 Posted December 19, 2016 Share Posted December 19, 2016 I've found if the oil filter isn't nice and tight it'll slowly drip onto the exhaust manifold or heat shields. Most noticeable after a coming to a stop after a high speed run. same with me, but its not the oil filter, its the passanger axle seal.. lines up right with the downpipe and spins lube onto it. only notice it when i am stopped too, but not for a long time. Link to comment Share on other sites More sharing options...
relative4 Posted December 19, 2016 Share Posted December 19, 2016 Any of the following could cause burning oil smell once they come in contact with the exhaust: Leaking valve cover gaskets Leaking oil cooler seal Torn cv joint boot And my nemesis leaking power steering pump + breather hoses on top of block (direct experience) + AVCS line (I've heard) Link to comment Share on other sites More sharing options...
